Is 12 Volt Gen 4 Battery Made of Gold?
Discussion in 'Gen 4 Prius Main Forum' started by ATHiker, Jan 23, 2019.
  1. Prodigyplace
    12,567
    11,781
    Central Virginia
    That is very short life for a Prius car battery
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I never realised that it was see-through (it's dark down there) - but someone on another thread commented that it was. I've taken a video, showing the fluid level, as I rocked the car.
    RobH and Mendel Leisk like this.
  3. alanclarkeau
    7,045
    7,592
    On a technical point - for those with OCD - the answer could be "YES - maybe".
    "The lead obtained from the blast furnace contains small amounts of some metallic impurities also contained in the ore. These can include the metals: copper, arsenic, antimony, bismuth, tin, silver and gold."
    Prodigyplace likes this.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    :eek: That's getting up near HV battery prices
    Andyprius1 likes this.
  5. Mendel Leisk
    41,480
    I've found you have to pull the battery out to do a half-way decent assessment of the electrolyte levels. Something worthwhile doing around the 3 year mark anyway.
  6. Prodigyplace
    12,567
    11,781
    Central Virginia
    That is because your battery is in the BACK. (& not Gen 4)
  7. Mendel Leisk
    41,480
    No, this was on previous vee-hick-ulls, with non-AGM batteries Some I'm sure you can see ok, but I always found I needed it out, with a strong light behind it, to see clearly.
  8. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    Just checked my OEM 12v. It's black plastic all the way around, so no easy checking of the electrolyte levels. The good news is that I can see where and how to pop the overall cover off to check when it's time.
  9. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    I've read several threads on GEN4/PRIME 12v battery issue and how expensive the replacement costs are. I don't have any problem with mine, yet. But I sure hope it is not going to cost any more than an ordinary lead-acid battery when it comes time to replace mine. My dealer runs battery special for $99 installed all the time, I wonder if they will honor the sales price for PRIUS?
  10. bisco
    51,966
    nope, that's only for 'normal' batteries. those specials drive me crazy. at least with oil changes, they know enough to put 'synthetic oil extra' in the fine print.
    Merkey likes this.
  11. Salamander_King
    11,019
    8,954
    New England
    Yeah, with Gen3 and earlier, I can understand they would charge more for expensive AGM battery. But Gen4/PRIME has ordinary lead acid "normal" battery, don't they?
    krmcg likes this.
  12. bisco
    51,966
    normal chemistry, but abnormal size. they'll never give you a $200. battery for $100. you'll be better off at auto zone.
    hopefully, pull never need one before more alternatives arrive!
    alanclarkeau likes this.
  13. Salamander_King
    11,019
    8,954
    New England
    Yap, I sure hope they will have plenty of aftermarket batteries available by the time I need to replace mine. For information, I drove Gen3 only 3 years, so no replacement was needed, but for my previous HCH, the OEM 12v battery lasted 9 years before needing replacement. With PRIUS, I would think it should last even longer than HCH.
  14. bisco
    51,966
    if you take care of, and don't run it down, i agree, especially in our climate.
    my '04 lasted 8 years, '08 lated 10 years. i'm pushing for 12 on my '12.:cool:
    Andyprius1 and Raytheeagle like this.
  15. Salamander_King
    11,019
    8,954
    New England
    I did not do anything on my HCH until it finally did not start in one winter morning after the main hybrid battery failed. I replaced 12v battery with the cheapest one found in local NAPA for ~$100 and had the IMA hybrid battery replaced at a Honda dealer for free under warranty. Thinking of buying good battery maintainer/charger but have not yet.
    Raytheeagle likes this.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    A personal @bisco challenge:).
    Good luck with this and what are the stakes(y).
  17. bisco
    51,966
    having to walk home or call for a ride :whistle:
    Lightning Racer and Raytheeagle like this.
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Sounds like a battery maintainer is in your future:).
    As I’m sure Mrs. Bisco won’t appreciate walking and you wouldn’t hear the end of it:love:.
  19. bisco
    51,966
    HCH doesn't have the sks drain, that helps
    Salamander_King likes this.
  20. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Hybrid Automotive (y).
