Is 35mm to much offset on custom wheels for a Gen 2.
Discussion in 'Gen 2 Prius Technical Discussion' started by monoshock, Jul 19, 2022.
  1. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    Thinking about some custom wheel, but these have a 35mm off set. Is that to much ?
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    If the OEM wheels on the Gen 2 are the same as the Gen 3, then the offset is 45mm.
    An offset of 35mm means that the wheel face will stick out about a half inch further toward the outside. Probably not a big deal, your track will increase by about an inch.
    Long story short, they'll fit.
  3. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    Thanks for the reply.
