Is 50 mpg at 65mph normal?
Discussion in 'Prime Fuel Economy & EV Range' started by White 17, Feb 27, 2017.
  1. White 17
    White 17 Junior Member
    59
    17
    Nor Cal
    I have trouble getting 50 mpg at freeway speeds. Slower speeds I can get more like 60 mpg but not at freeway speeds. I have tried it on flat ground resetting the trip odometer and a constant speed for 10 or so miles and on longer trips. I think the dashboard reading is probably a little optimistic compared to hand calculated readings, still I don't get EPA est of 53. 70 mph is even worse. Anyone else notice this?
  2. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    I drive 79mph on highway all the time. I have 46MPG with Costco gas. The dashboard reading is ~50, 51.
    65mpg_utahn likes this.
  3. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    See #207 of "Prius Prime Plus in my hands" by Mr. Bob Willson. Temp, altitude, terrain, tire pressure, cargo weight, etc may influence MPG.
  4. bwilson4web
    16,533
    This is my model and validation data points:
    - The curve is generated from the EPA roll-down coefficients and 40% engine efficiency
    - The Prius Prime Plus had fully inflated tires (max sidewall), engine oil, and transaxle oil change
    - Temperatures were 59-62F, low to no wind
    - Two runs, same route, opposite directions, 10 miles each way, summed fuel and distance for both, excludes acceleration
    - Speed cruise control managed, ~1.6% error compared to GPS metrics
    - Outlier, 35 mph: did not have a full, 20 minutes of warm-up; coolest temperatures and; was a loop
    - On-curve, 35 mph: bi-directional in afternoon after doing hill climb and descent run
    #4 bwilson4web, Feb 27, 2017
  5. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    The EPA does not run the test at 65 mph
    Trollbait and jerrymildred like this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    That looks about right for that speed. To get an idea of how strong air is, hop on a motorcycle & ride along at 50 mph. Get a feel for the force of the air. Then crank it up to 70 and feel the difference.
  7. Trollbait
    12,824
    The EPA highway test is based on rural roads. The top speed is 60mph, but the average is 48.3mph. Then acceleration on it and the city cycle is very gentle.
    With speeds faster on a freeway, you will get lower than the window sticker on them.
    Detailed Test Information
  8. Mendel Leisk
    42,343
    Bob's graph is very telling: in the middle, pretty much a 1:1 inverse relation, between mph and mpg.
  9. bwilson4web
    16,533
    Clever, I hadn't notice (missed the forest because of these fascinating trees.) But it sets up a 'rule of thumb':
    • 120 = MPG + mph :: 35-70 mph, +/- 5 mph or 5 MPG
    So within the 35-70 mph range, we can say:
    • MPG = 120 - mph
    • mph = 120 - MPG
    So who is going to win the first bet with this bit of math nonsense?
    jerrymildred and Mendel Leisk like this.
  10. TinyTim
    TinyTim Active Member
    418
    243
    Seattle
    Is there a specific tire pressure on the 15" tires that a person should keep to get the best MPG? I know the manual but has anybody tinkered with tire pressure to find optimal performance?
  11. Mendel Leisk
    42,343
    The equation goes well in the middle, not so good at the extremes where the graph flattens, and even reverses. But really hits home: going faster costs.
    #11 Mendel Leisk, Feb 27, 2017
  12. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    I get 48 mpg at 75 mph.
    winter tires gave me 44 mpg at 75 mph
    From Portland to Seattle and back.
  13. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    I wonder about the Tire Pressure as well. Just got my first oil change today, and they recommended 36 for FRONT and 35 for REAR. What do you guys think? The interesting thing is that my tires were at 48/50 and the max is 44. I have no idea why it would be that high. I have not touch them since I got the car on 11/11/16.
  14. jerrymildred
    11,517
    14,167
    Tampa, FL
    If you checked them hot, they will read high. Quite a few of us run the tires higher than recommended -- some even at max sidewall pressure. My max is 49 or 50, iirc. I run mine at 47/45. But dealers will often take it upon themselves to set your tires at the pressure on the door panel regardless of your wishes. Recommended pressure will be a little softer and quieter than where I run mine.
  15. Mendel Leisk
    42,343
    They leave the factory at high pressure, to avoid flat-spotting before sale. Dealership is SUPPOSED to lower to spec during Pre Delivery Inspection.
  16. bisco
    52,848
    there are no tyre pressure tests that i know of, any info here seems to be guesswork at best.
  17. bisco
    52,848
    is this hv mpg we're talking about? phev mpg? or gas only mpg?
  18. Trollbait
    12,824
    I've heard of the tires being pumped up before loading on the ship to allow for pressure loss during transit. If true, perhaps your dealer hadn't adjusted them for delivery.
    For fuel efficiency, higher tire pressure is better. The recommended levels for the manufacturer err on ride comfort, and they also apply to the tires that came with the car.
  19. zxcvbn
    zxcvbn Junior Member
    space
    Remember that cold air in the winter is denser that warmer air in the summer, which increase aerodynamic drag at highway speeds, lowering your MPG a little bit.
  20. ajpn
    ajpn Junior Member
    30
    16
    I got over 52 mpg driving between 70 and 80mph from San Diego to Placerville, California. 0 percent EV charge to begin. From 8:30pm to 4:20am, mid 60s to low 50s temperature. I stopped to eat once and later to get gas between Stockton and Sacramento. Roughly a 550 mile drive. Gassed up at approximately 480 miles with 9.2 gallons. This was on the day I bought the car mid December.
    Andyprius1 likes this.
