Is 50 mpg at 65mph normal?
Discussion in 'Prime Fuel Economy & EV Range' started by White 17, Feb 27, 2017.
  1. bwilson4web
    16,537
    <AHEM>
    One thing I read about but don't have the citation is tire resonance leading to higher drag. At higher speeds, a tire can setup a resonance that increases the rolling drag and tire heat. This is a complex phenomena but making the tires 'stiffer' with higher pressure should reduce this effect.
  2. 65mpg_utahn
    65mpg_utahn New Member
    St. George, UT
    2014 Prius c
    I always buy Costco gas and can get 65 mpg in town and 52 hwy. I don't have much of a lead foot I like to ease onto the freeway.
  3. Michael Nielsen
    67
    89
    Dover, DE
    I have logged around 2,500 miles on a road trip from Delaware to Arizona, generally driving at 70 mph with a passenger and our stuff. 46 mpg.
  4. bwilson4web
    16,537
    You might consider adding to our knowledge using one of your trip meters:
    • Wait 20 minutes into a first drive, 5 minutes on subsequent drives - to warm-up the car.
    • Set your cruise control speed, dynamic or ordinary.
    • Reset the trip meter and note the location (longitude/latitude is perfect) but City/State is good enough
    • When ready to pull off, note or photo the trip meter and note the end location
    • Record head-wind, tail-wind, and approximate strength and temperature but we can look up the weather records closest to your route
    We can use the one-way, benchmarks to compare against the mph vs MPG chart. Not perfect, good enough to help everyone understand what the car does. This approach removes the warm-up penalty and helps account for weather, temperature, and altitude changes.
  5. bisco
    52,861
    those charts are great, thanks bob. any chance of a simple mpg vs tire psi chart for the great unwashed?
  6. bwilson4web
    16,537
    I wish there were but it is not that simple because we still have to deal with all of the other variable: fuel, warm-up, temperature, e.t.c. But there may be a way to indicate a percentage improvement. Let me think about it for a bit.
  7. James Wells
    James Wells Junior Member
    35
    28
    Austin, TX
    1,800 mile drive from Austin to NYC. 54.3 mpg freeway at 70-80.
    jerrymildred and bwilson4web like this.
  8. MattStevenson
    MattStevenson Member
    57
    35
    US
    Ambient temperature plays a huge factor but basically anything above 55mph is wasting gas. Airpressure on the front of the car builds drastically above that speed. That's why many states had a max speed limit of 55mph for a long time.
    RJ Primw likes this.
  9. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    I also wonder after the ice fully breaks in and looses up a bit, if then mpgs get better
  10. bisco
    52,861
    seems like a dyno in controlled conditions would be the best way?
    #30 bisco, Feb 28, 2017
  11. bwilson4web
    16,537
  12. White 17
    White 17 Junior Member
    59
    17
    Nor Cal
    I haven't checked the prime but another car I have is about 10% high on the dash MPG readout compared to using a calculator. It is hard to do with the battery mixed into the equation. Perhaps we should be using some sort of correction when using the MPG readout.
    bisco and Mendel Leisk like this.
  13. bisco
    52,861
    on the pip, it gives you hv/ev miles on the trip meters. makes for an easy calc at the pump. is there any way to do it on prime?
  14. White 17
    59
    17
    Nor Cal
    I haven't found that yet.
  15. bwilson4web
    16,537
    #35 bwilson4web, Mar 4, 2017
  16. White 17
    59
    17
    Nor Cal
    I did a 600 mile trip this week and kept track of the hand calculated and trip meter readings. I started with a full tank and nearly zero charge reset the A and B trip meters. I filled three times and reset the B trip meter each time.
    First fill up calculated at 56.5 mpg and B trip meter was 59.2 mpg or about +2.7 miles/+4.8%.
    Second fill up calculated at 62.0 mpg and B trip meter was 61.7 mpg or about -0.3 miles/-0.5%
    Third fill up calculated at 54.8 mpg and B trip meter was 57.6 mpg or about +2.8 miles/+5.1%
    Total for trip calculated at 57.1 mpg and A trip meter was 59.1 mpg or about +2.0 miles/+3.5%
    I almost had a pattern there but the one check kind of messed up perfect. Right now it seems like it might be the meter reads two to three miles over. I will try it again next week on another quick trip I have planned.
    Also, I suppose it really doesn't matter about the battery charge EV miles added as that is still going to be on the trip meter calculation and should compare to the hand calculation. I would make a difference if I wanted the gas MPG only. I guess that is poorly said but anyway.
    As to the actual mpg numbers they are better than I was getting before. Speed was mostly over 50 and no more than 65. Can't explain it but I shouldn't complain either.
  17. pricoaster
    pricoaster Member
    72
    84
    Los Angeles
    On the Drive Monitor screen, it will show you the EV Driving Ratio based on the current trip monitor you have selected (ODO, Trip A, Trip B or since Last Start). By multiplying this percent by the miles logged in the trip monitor, that'll give you the miles driven in EV mode and the difference is the miles driven in HV mode.
    For example, the attached pic shows Trip A (since my last visit fill-up at the gas station, which was on Feb 4th). I've driven a total of 1,017 miles, with a 76% EV driving ratio, meaning I've driven about 771 miles in EV, and 243 in HV. I didn't take a pic, but the distance to empty is around 220 miles. And I have about a half tank left, so it's generally accurate.
    jerrymildred likes this.
  18. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Has anyone ever taken a look at the "Eco-Diary"? Last one under drive information.
  19. Lee Jay
    5,850
    4,036
    Also, why do people assume the gas pump is ground-truth? It's not. The pump can be off and you are dividing by miles accumulated on the odometer, which can also be off.
  20. Mendel Leisk
    42,352
    I do because the laws of the land come down hard on both those, if they're off.
