is a special fault code machine needed for hybrids
Discussion in 'Gen 2 Prius Main Forum' started by fna, Aug 21, 2013.
  1. fna
    fna Junior Member
    I am looking to buy a used prius. Looked at a 2008 and when I took it for a buyers check, my mechanic told me that it came back with a C2300 and C2318 (both transmission related). I passed and told the seller.
    The seller took it to the dealership and the dealership said that false positives happen when you hook up a hybrid to a non-hybrid code detection machine. They are claiming that they are not seeing any codes. Not sure if he is blowing smoke up my backside. Are the machine really that different where a hybrid needs to be hooked up to hybrid specific fault code machine ?
    Thanks
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The short answer is yes. The Prius has several ECU's that control the hybrid system that standard code readers cannot communicate with. You need a Prius specific scanner to read the proper codes.
    Some Advance Auto and Auto Zone's can read the Prius specific codes for you. Of course the dealers have the Techstream software made for the Prius.
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Welcome to Prius Chat!
    Ask the seller if you can take the car to a Toyota dealer of your choice and pay them to pull the codes and do a courtesy inspection. While they are looking at it, they can check the traction battery and other items. As said above, Generic code readers don't always pick up all of the Prius codes, plus sometimes they can misdiagnose (give wrong code). Techstream is the best (Toyota dealers). There is another code reader you can use on a laptop, but I can't recall what the name of it is.
  4. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Just to add to the above, the difference is not strictly hybrid vs. nonhybrid, but just that the Prius has so many proprietary ECU's compared to other cars. I am not sure as to the root cause of the false positives returned by some generic readers, but it may have to do with the bus protocols or bus speed used in the Prius, as necessitated by all that extra traffic.
    The list of Prius capable readers includes: The Torque app for Android phones, ScanGaugeII, and the miniVCI (eBay). Autoenginuity has not proved reliable for some PC'ers, but hopefully is improved by now (?). The cost of going to Toyota just for a scan makes ownership of one of these options more than worthwhile. Such is the current era's equivalent of opening the hood and checking the oil. (Which Prius owners need to do as well!)
  5. fna
    fna Junior Member
    bumping thread. to get over post limit. have a legit question but it wont let me post.
