Is EV button/mode a novelty??
Discussion in 'Prius c Main Forum' started by GRich, May 13, 2013.
  1. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    How? I can drive with the ICE off up to ~46 mph, but regardless of anything else, if I push the pedal past the first section of the eco meter the ICE will go on, even if I'm in EV mode.
    RocMills likes this.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    You already have an EV indicator. When the symbol illuminates, it means the system is warmed and the engine has shut off. That's STEALTH mode. Pushing the button then will switch you to EV. You also already have indicators for how much is available, both power & duration.
    All middle-market vehicles have omissions of some sort, that's why they are middle.
    Having the option to add more to see more is available, but that won't change the limitations of motor & battery.
  3. GRich
    GRich Junior Member
    28
    16
    Of course they have emissions, no said the did not. I just want a simple indicator when I turn on the car and press the EV mode which one I'm in mode in and where the ice will start. So as I'm driving out of parking lots or my apartment I know what the what mode 10 or 25 I'm in. I drive and make stops for work all day, 5-6 stops. It would be a great if I push the button in the lot before the ICE has started I knew which EV mode so I could according to its limit. I'm not asking for any additional motor or engine limitations just an indicator.
    if funny you act like an apple fan boy " market research shows, no one needs multitasking on a Iphone" Iphone four comes out " Iphone has multitasking because the are so awesome".
  4. john1701a
    12,840
    5,312
    58
    Omissions not Emissions. Some features are omitted. That's the way competitively-priced vehicles are configured. You want more, you pay more.
    That would be a safety compromise. Not offering it is the same reason other features become locked when the vehicle is in motion. Just drive it.
    If you really want that indicator, use an ODB-II device. But keep in mind how often that indicator will actually change though. There are more variables at play than what the generalizations discussed here want to address.
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    This is the EV only/ EV mode misunderstanding... again.
    EV mode (where you press the button) gives you a max speed of 25mph when the engine is warm. It drops to 9mph when the engine is still cold. During this time when you have the button pressed you can accelerate past the middle eco line but not all the way up to the pwr line. It's somewhere in between and is never consistent.
    EV mode (where you don'e press the button but release the gas pedal) gives you a max speed of 46mph when the engine is warm. You are limited to the Eco line in this mode.
    minkus likes this.
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    But since it is never consistent, a little user friendliness would be nice. I like the thought of changing the bar to a different color the closer you get to the threshold.
  7. Mendel Leisk
    42,303
    I've very rarely noticed being a bit to the right of the center line, and am still in EV mode. Usually when the state of charge is quite high.
    (Clarification: by EV mode I didn't mean with the EV button depressed, just the car's decision to shut of the engine. What's referred to as Stealth Mode.)
  8. minkus
    369
    125
    Cleveland, OH
    That's the clarification I was looking for! I didn't know this was possible - apparently all the times I've tried it, the engine was too cold or I went over a bump or it thinks I accelerated too fast. Thanks!
