Is Gen4 an Aztec of 2010s?
Discussion in 'Gen 4 Prius Main Forum' started by cyclopathic, Oct 31, 2015.
  1. bwilson4web
    16,217
    I'm pretty sure the Sonata is a sedan and the Prius a hatchback. There are folks who don't care for a hatchback which I suspect will be the case with the Gen 4. However, the classic problem of hatchbacks, sound and handling, may be addressed with improved sound proofing, suspension, and stiffer body.
    I'm using www.fueleconomy.gov.
    #61 bwilson4web, Nov 2, 2015
    51,948
    you mean like a camry?
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    I've rented Gen6 Sonata back in 2012 and handling was below our Gen3. Gen3 had a rear sway bar and STB at that point, but even w/o them they were not that far apart. I will look up noise data, but as I recall Prius G3 was rated as very quiet so this is likely not an issue.
    You're right there are people who still do not like hatchbacks, but this is of the past. SUVs had made 5th door socially acceptable. You can name dozens of them on the market. I doubt this is the main issue, and it would explain why redesigned Sonata sales doubled, and redesigned Prius did not.
  4. Tideland Prius
    16,559
    I got 1760mm from that Tokyo Motor Show press release.
    No, unless they're planning on making the next gen CT even better, then there might be some overlap between the current gen CT and the 4G Prius. They could also differentiate the two by offering a CT200h and CT300h with the Camry setting. That way, they can sell the 200h in markets were engine size has tax implications and sell the 300h in other markets like the U.S. who prefer a bit more power.
    Pontiac Aztek GT - Road Test - Car Reviews - Car and Driver
    AzteK. Again, Aztec is a group of people.
  5. cyclopathic
    3,292
    547
    2014 Prius c
    IMHO it will be at or slightly better than Scion iM, which mag reviews found interior to best in class Mazda3. I drove 2015 Mazda3 and was underwhelmed; my mildly modified C out-handles it. Not to say Md3 wouldn't be a better starting point for mods.
    I just can't see them spec'ing good shocks or rear sway bar on Gen4, and with soft springs and oversized front sway problems will be the same.
  6. Tideland Prius
    16,559
    Well I guess we'll find out in less than a month (depending on whether there's an embargo on test drive articles). I'm really curious to see how the Gen 4 drives.
  7. cyclopathic
    3,292
    547
    2014 Prius c
    It doesn't take much to improve Gen3. Ours has rear sway bar, STB, camber kit and rear Excel-Gs and it outhandles tires. We drove through fingerlakes 2mo ago, no complaints.When Gen4 comes out I will give you my opinion.
    Tideland Prius likes this.
  8. Tideland Prius
    16,559
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Actually, the Pontiac Aztek was spelled ending in k
    Pontiac Aztek - Wikipedia, the free encyclopedia
  10. Netcub
    Netcub Active Member
    344
    170
    Kentucky
    I'm not sure which version of the internet you have installed, but Aztek is spelled with K, not a C. You might want to check some of your other posts for spelling errors also, before calling out others... I'm not sure why you continue to troll these forums or why you are even allowed to. It's obvious from the responses to your posts, you are adding little, if anything to the conversation here.
    giora likes this.
  11. Mendel Leisk
    41,463
    Someone should be banned cus he disagreed with you AND misspelled something? C'mon.
  12. frodoz737
    frodoz737 Top Wrench
    4,699
    2,497
    33
    Considering this is his thread you mean? The fact that you disagree doesn't forbid you from participating. And just a heads up, nobody likes spelling Nazis on 4umz.
  13. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Nazis? did someone say Nazis?
    Our first play of our season was The Producers, by Mel Brooks.
    Greenwood Little Theatre - A Community Theatre in Greenwood, Mississippi
    Five years ago, when we did Sound Of Music, I bought props on eBay, and had issues getting off the mailing lists of Nazi enthusiasts.
    (I had to dye my beard black, as I looked too much like Captain Crunch and not sinister enough with a white beard)
    Now I needed to get props for Springtime for Hitler. <sigh> Once again I run up against a shortage of commercial Third Reich props from uninterested sellers.
    When I first envisioned what I needed I thought I wanted 16 foot banners, as 'fixed' props, but my director decided he wanted his actors to precess in with the flags so 4 by 8 seemed a more sensible size. They wound up 4 by 9 and they came down from the loft.
    Sewing a swastika is much easier if you assume it is a black square then add the small white stripe from each side. (for some reason it is very hard to find swastika makers for advice on this)
    Now you hook it to a pole you fly from the loft. The fringe hides weights.
    Here is the Springtime for Hitler production number, you can see the banners add a lot to the set. (my wife is in purple on the right)
    (had the director allowed me 16 foot banners they would have been fine. Anyone need stage props for Sound of Music or The Producers?)
    #73 JimboPalmer, Nov 4, 2015
    bwilson4web likes this.
  14. cyclopathic
    3,292
    547
    2014 Prius c
    By any choice you are not working for Toyota? Since registering in 2009 there were 66 posts made from Netclub account, 62 of them in Gen4 forum, just as this all started. Most of it slamming the Hyundai, GM or Ford Probe comparisons and defending new Prius.
    Prius is a great car (we have 2), but IMHO Gen4 is a disappointment. Too little, too late. IT is like going to a restaurant and ordering a meal and 3hr later finding out someone ran across the road and got you McDonald kids meal. And look no sh!t it came with a toy, so shut you Fing opinion of our great Toyota establishment. Or something like that, you fill it in.
  15. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    That's a nutty analogy.
    There's *still* nothing to compete with a Prius except another Prius! Show me another liftback that's just as large and has the same or lower total cost of ownership. The Volt has about half the range and a far smaller rear seat. The Tesla has a third the range, takes forever to refill, can only be refilled in a few places, and costs as much as a small house. The Hyundai isn't out yet. The Insight gets worse mileage and has less interior room by a lot. The Camry isn't a liftback. The Rav4 is way taller, will get *maybe* around mid 30s for MPG, has much higher step height, and will be much more reminiscent of driving a truck than a car.
    Your objections are based almost entirely on exterior looks, something which is subjective and for which the Prius has never been known anyway.
    From most current information, the underlying technology is dramatically improved over the already best-there-is. Better thermal efficiency, better drive train efficiency, better handling, more responsive, quieter. The numbers on the internals are more head room, more comfortable seats and driving position, more total cargo volume, more cargo area width. And there's E-Four if they ever pull their heads out and make it available to people who might actually want it.
    To me, there just isn't anything out there than do what a Prius can do - carry 4 people very comfortably, get 50+MPG doing it, fold down to became capable of hauling very large objects or huge numbers of smaller objects, and do all of it at a modest cost with exceptional reliability and ridiculously low total cost of ownership.
    TonyWilkey and energyandair like this.
  16. cyclopathic
    3,292
    547
    2014 Prius c
    Actually the comparisons are based on current Gen3. And Gen4 isn't step forward, it is a side step at best. In many ways it is a step back, in a few forward. Loss of storage compartment, loss of glove compartment, dubious or even repulsive looks and largely irrelevant MPG gain. Anything else? or yeah, unverified "handling" improvements. Will it handle better then Scion iM? very unlikely. Does Scion iM handles better than my Gen3? no, tested. Granted Gen4 will not need STB, so it will take $130 less to make it handle.
    Cost of "fixing" Gen3 was $125 STB, $200 sway bar, $100 pair of rear shocks. $20 camber kit you do the math.
  17. Lee Jay
    5,850
    4,036
    I don't know what an STB is and you didn't include the labor costs so I can't do the math.
    Large and very relevant MPG gain (any drop of oil we don't buy from people who hate us or that doesn't get put in the atmosphere matters), greatly improved overall looks (which is irrelevant anyway), and there was nothing wrong with handling on the G2 or G3 in the first place. And you forgot about quieter, more responsive and more comfortable. The problem with the G2 and G3 suspension was ride harshness, especially over cross-road divots or cracks.
    I'll grant you that all of this is unverified as of yet, but that's the way with anything you haven't gotten to see for yourself.
    The main reason I'm interested in a G3 is because of the loss of storage in the G4. The main reason I'm interested in a G4 is the improved ride and quietness. I'll see those for myself. In the mean time, I'm keeping my G2 and not really even looking at other manufacturer's vehicles or other vehicle options from Toyota.
  18. bisco
    51,948
    if mpg are irrelevant, why would anyone buy a prius?
    Lucifer, PLSPUSH and bwilson4web like this.
  19. frodoz737
    4,699
    2,497
    33
    I think we are just measuring now. You either like it or you don't..that's it. Rational to buy any car is subjective. I still want a GTR...and some think it's ugly too.
    cyclopathic likes this.
  20. cyclopathic
    3,292
    547
    2014 Prius c
    Could you please read more carefully? "MPG gain" not MPG. 15,000mi = 300 gal. 10% better MPG = 27gal saved, or 2.25gal a month. $4 in current gas prices. So you need to spend $25,000 to save whooping $4 a month? Please tell me how relevant is it?
    To Jay: if oil dependency is your main concern, get electric car. Better yet don't buy any plastics and don't drive on black top. As you guess they are all oil products.
