Is Head Gasket failure common in Gen 3?
Discussion in 'Gen 3 Prius Technical Discussion' started by JohnStef, Nov 29, 2018.
  1. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    Is this pretty common on the Gen 3?
    Is replacement of the gasket all that is required, or does this cascade into other failures?
    Are there other things more than the head gasket that fail?
    52,397
    depends on how you define common, i think not.
    first your egr clogs, then your head gasket blows if you don't do something about keeping the egr clean
    nothing else fails, but a head gasket is not simple like in some cars, most require a new/used engine
    2014 and 15 have improved piston rings which (may) help
  3. Mendel Leisk
    41,921
    I stand in awe of that. :ROFLMAO:
    52,397
    blown head gasket after ego clogging = :mad:
  5. Mendel Leisk
    41,921
    I'd second the need to get on EGR cleaning early on, ditto for intake manifold cleaning and an Oil Catch Can install on the PCV (Positive Crankcase Ventilation) circuit, to prevent the intake manifold promptly gooping up again.
    When head gasket fails, depending how it fails, it might fill a cylinder with coolant, which can bend a piston rod.
    Also, head gasket replacement can be an expensive gamble. It's a lot of labour, often simpler to drop in a low-mileage engine from a wreck. That can be a crap shoot too.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Definitely best to get on the egr circuit early;).
    I think we just saved a 2011 CT200h out here a couple of weekends ago by doing that at 159k miles:).
    I’d pair the job with either the spark plugs at 120k miles or the engine coolant at 100k miles.
    I did round #1 of the egr circuit at around 120 k miles and again at 175 k miles and glad I did;).
    Good preventative maintenance item(y).
    Lukey51, Montgomery and m.wynn like this.
  7. PriusCamper
    PriusCamper Senior Member
    13,078
    5,306
    Pacific Northwest, USA
    For the reasons described above, head gasket failure is more common in Gen3 Prius than it is in Gen2 Prius...
    ErikaRachel and JohnStef like this.
  8. JohnStef
    JohnStef Member
    127
    Dewitt, Mi
    I would repair this if the chances are good. A replacement engine, in central Michigan is running $1100. A Prius Chat poster said he replaced a Gen 3 head gasket for about $400. The car I'm looking at has 210k miles, the owner says "the head gasket failed and is burning coolant, the engine runs good but is making a little noise".
    Any thoughts on "making a little noise"
    m.wynn likes this.
  9. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    The rod is about to emerge from the block:eek:.
    Find a new engine and replace it don’t try to do the head gasket in this one;).
    It’ll save you some grief if you are determined this is the cat for you(y).
    Montgomery, m.wynn and PriusCamper like this.
  10. Bill Norton
    Bill Norton Senior Member
    2,219
    746
    MONW, Ks.
    2019 Prius
    L Eco
    BUT,, how can these 'reasons' and 'Good prevent. maintenance' claims be verified?
    My '11 at 182k miles is going strong. My bank courier buddies' Gen3's are going strong at +400k and 600k miles.
    All without dikin with the EGR circuit. Maybe mostly highway miles helps keep this circuit flowing? Who knows?
    If it is life or death, why is it not officially mentioned within Toyota's long term maintenance schedule?
    I'm just asking, Technically Speaking, how is a choked down EGR circuit going to lessen the life of a head gasket?
    Drew Michael likes this.
  11. bisco
    52,397
    it's all in danlatu's thread.
    Montgomery and Raytheeagle like this.
  12. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    He’s read it several times:cool:.
    But maybe soon he’ll come around(y).
    Montgomery, m.wynn and bisco like this.
  13. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Does a cat have whiskers?
    #13 mjoo, Nov 30, 2018
  14. bisco
    52,397
    as for why toyota doesn't have it in their long term maintenance schedule, there's a lot of things like throttle body cleaning, tranny fluid, etc. it's called 'marketing'. as long as it doesn't blow up under warranty, everybody's happy.
  15. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Forums like this are where you find the shallow graves ;).
    Once you find them, knowledge is power(y).
  16. Mendel Leisk
    41,921
    There is a Technical Service Bulletin for the Exhaust Gas Recirculation, but requires advanced symptoms and/or a code, and by that time...
    Montgomery, JohnStef, m.wynn and 2 others like this.
  17. jack black
    jack black Active Member
    225
    142
    I
    I'm thinking, maybe the restricted EGR folks used low quality gas? I remember first reports of clogged EGR came from Europe. Not sure why.
    I didn't crack the EGR cooler yet, will do it next spring or summer, But I did check the EGR pipe condition at 70,000 miles and there was only light coating. I use only quality brand gas.
    Drew Michael and padroo like this.
  18. PriusCamper
    13,078
    5,306
    As many of the earliest threads on PriusChat will vouch for, the Gen1 and Gen2 was designed to run on lowest grade gas. I assume that's the same for Gen3...
    As for using higher quality gas, my understanding of what that means is they add extra additives to boost octane, as well as other stuff. But how that higher octane / additives would help prevent the oil in the crankcase from gumming up EGR system to the point your system is cleaner and you're at less of a risk for a blown head gasket is beyond my understanding. Maybe someone will add to this thread more detail about how that would work? Perhaps the detergents in higher grade gas keeps the intake manifold and ports cleaner?
    Travis Sanders and mjoo like this.
  19. Mendel Leisk
    41,921
    Maybe nothing to see here?
    m.wynn and Raytheeagle like this.
  20. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    I use top tier gas and the deposits form;).
    All the additives do is extend the time it takes for the deposits to occur. I also add BG Products 44k every year (which is essentially highly concentrated Techron) too:).
    So +1 to nothing to see here(y).
