Is it fairly common for rear struts to get noisy (170k miles)!
Discussion in 'Gen 2 Prius Main Forum' started by MilkyWay, Feb 20, 2017.
  1. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Reason for thread is I'm not a mechanic but when you are sitting in the backseat seem to really feel the bumps. A little creaky also....Just wondering if it is a common repair...Bought with 140k and currently has 170k so I do not know the history on this car...probably original
    51,155
    anything at 170k is common.:p
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    953
    533
    Cow-lee-fornia
    2023 Prius
    That's not the bad news. Bad news is the rear suspension requires new components to be installed when they go out of spec. Guess what happens when you replace the rear shocks?
  4. MilkyWay
    823
    359
    23
    MI
    I have no idea. What components
  5. Patrick Wong
    18,200
    6,493
    The OP and rear seat passengers will experience an improved ride.
    MilkyWay and Raytheeagle like this.
  6. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    If you do the job, it's not a bad idea to go ahead and replace the rear coil springs as well. No extra labor involved. Did mine at 130k, And the rear end stood up noticeably higher afterwards. Now I notice Gen II Prius with sagging rear end.
