Is it just me or is the steering wheel control backwards?
Discussion in 'Prime Main Forum (2017-2022)' started by Jeff Hicks, Oct 11, 2019.
  1. Jeff Hicks
    Jeff Hicks Junior Member
    37
    24
    Huntsville, AL
    2020 Prius Prime
    I have the 2020 Limited and the audio preset skipping function via the steering seems backwards to me. When I push the left side button it advances in the presets and vice versa. I can not get used to this and does anyone else see this as backwards?
    Just curious.
    TGrracie likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    They are labeled with up and down arrows and the list (iirc) is vertical. Nevertheless, after seven months and 11-12k miles, I still hit the wrong one sometimes. :oops:
    I think a more user-friendly button layout would have been an up/down rocker for volume and another rocker for presets.
  3. Prim.e.xample
    Prim.e.xample Active Member
    164
    107
    Indiana
    2020 Prius Prime
    I do the same thing and have worked hard to remember up is up the list. Have you tried rearranging your presets? I like to order mine from lowest to highest so I know where I am in them. But maybe I’m a little OCD...
    iPhone ?
    benagi and jerrymildred like this.
  4. Jeff Hicks
    37
    24
    Huntsville, AL
    2020 Prius Prime
    That might work! My parents transferred their lifetime XM to me. I put in about 20 XM presets and it is driving me crazy, I’ll try to set them up in reverse. If I could figure out the logic or reasoning as to why it works the way it does, I might be able to remember to go left to to advance my presets
    ps I had a little of a hard time getting used to lifting up on the shift knob to go in reverse. I kept wanting to lift up on the knob to go forward. In a way the beeping, while annoying helps me to confirm I’m in reverse.
  5. Tideland Prius
    16,445
    Yeah. Must be the youngins lol.
    It’s basically up and down the list of stations/presets (think vertically) rather than up and down the preset number.
    I rarely change radio stations so it still confuses me. Fortunately up still means next track (iPod/BT) so that works for me.
  6. ctscoob
    ctscoob Junior Member
    56
    36
    CT
    2020 Prius Prime
    Yes and the volume controls make me especially crazy. On my Tacoma the left and right buttons were for volume. On my ‘20 Prime Limited they are the top and bottom ones. I will never get used to it!
  7. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    I brought that up when I first got mine too.
    I think the way they intended it to work is to go down on the list of stations (the opposite of what my Gen3 does). If you pull up the radio stations on the big screen, they advance downwards. So down is up. I hope that makes sense. If it's any consolation, you do eventually get used to it.
