is it normal for this end cap to come off outer axle?
Discussion in 'Gen 2 Prius Technical Discussion' started by prius_newb66, Dec 18, 2022.
  1. prius_newb66
    prius_newb66 Junior Member
    62
    17
    Chicago
    My passenger side axle was kinda stuck and when I got it loose this end cap was stuck in the steering knuckle. I got it off undamaged, but how secure is it supposed to be to the axle? Is it ok to reinstall?
  2. ChapmanF
    19,045
    Isn't that the wheel bearing dust cap? The knuckle is where it belongs.
    It may have a hole that needs to align with the wheel speed sensor.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    yes and yes, it does.
    Assuming I'm remembering correctly, the ring area near the base of his thumb inserts into the knuckle and should be a tight fit. It doesn't go on the axle, it should be stuck to the knuckle. The speed sensor should be "looking" through the oval shaped hole so it can see the tone ring.
  4. prius_newb66
    62
    17
    Chicago
    Thank you both for that information. I wasn’t sure if the cap was part of the knuckle or axle. Really appreciate it!
