Is it normal to have a dead 12V after 2 weeks of non-use?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Halcykon, Apr 21, 2020.
  1. Mendel Leisk
    41,464
    No no. I'm just thinking, these "tests" of the battery are not what's needed. Long term downtime, punctuated by only short drives, is detrimental to any battery. Doesn't indicate it's defective. With modern cars there's a steady low level drain. Near daily use, you're ok. If not, then you're not. That's just how it is.
    Read up a bit, get an appropriate smart charger. I believe for 4th gen the Owner's Manual recommends 5 amp max rating? And with sporadic use, just use the charger round the clock. If that's not practical, consider disconnecting the neg cable for the down times.
    #21 Mendel Leisk, Apr 23, 2020
    jerrymildred and Halcykon like this.
    51,950
    i mean when you're toggling back and forth between two threads, it's hard to keep track of what has already been discussed, and responders may be repeating advice already offered in the other thread, or even their own past advice.
    and it can be difficult for the o/p as well, trying to keep track of it all.
  3. Davis Prius
    Davis Prius New Member
    New York
    Hello All: New to forum. And also the Prius is not my personal car, but due to Covid-19 and living arrangements, the car had sat for over 30 days so the 12V batter issue is not the only problem. Upon trying to start the car on a jump, the engine turned over, but displayed a series of messages "Smart Key System Malfunction, Braking Power Low, Antilock System Malfunction and Shift System Malfunction, along with a number of warning signs on dash and then shits off. Also, found the underside of the insulation above what i think is engine or inverter scortched. Ive attatched picture.
    I have another vehicle, but getting service or towing is tough right now. Any thoughts? Battery? Something far worse?
  4. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Can you please take another good quality picture of what's damaged below your first picture ?
    Rob43
    Salamander_King likes this.
  5. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Wow! This is a new development. Do you have a battery charger? I guess you did not check the 12v before trying to jump? I can't offer much help, but I would definitely try to determine what caused scorching of the insulation and any collateral damages caused by it before trying anything new.
  6. Halcykon
    Halcykon Junior Member
    35
    Sugarland
    2018 Prius
    Based on another thread I decided to get the BatteringMinder 1510. The CTEK looked good too but is currently out of stock on Amazon.
    (Looking back on the thread, I realized I was reading your recommendation on the CTEK!)
  7. Davis Prius
    New York
  8. krmcg
    2,592
    2,392
    Whittier, CA
    looks like the insulation under the hood.
  9. CooCooCaChoo
    CooCooCaChoo Senior Member
    957
    535
    Cow-lee-fornia
    2023 Prius
    Yeah, that looks like rodent damage, not scorching from a fire. Where did the car sit for the entire month?
    You do know that rodents are attracted to the wiring harnesses because its made of soy, right?
    jerrymildred likes this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    You beat me to it. I don't see any scorching in that picture. Something cut or chewed the insulation. If they got into the wiring, it could be anything from a simple tape job to something disastrously expensive.
  11. Halcykon
    35
    Sugarland
    2018 Prius
    Update: My prius still has a parasitic draw. I'm about to be on my 5th battery now after 7 years of ownership.
    I had my most recent 12v Trustart battery for 1 year and 1 month. Then I went on vacation for 12 days and came back to a completely dead battery.
    I still haven't figured out the issue. I've had the parasitic drain test done at Toyota and they couldn't find anything.
    Between my 3rd and 4th battery, I've just used my trickle charger whenever I went on vacation, but couldn't do so when I moved to a new apartment.
  12. bisco
    51,950
    you might have to add a quick disconnect to the negative cable. since it has been determined that the draw is normal when the car is off, the only other remedy is to drive more.
    have you considered selling it and buying a non hybrid? you're not saving much on gas.
    #32 bisco, Jun 16, 2025
  13. Mendel Leisk
    41,464
    Second the disconnect switch,or if the vacations are rare, just disconnecting negative cable will do.
    It would be good to check parasitic draw for yourself. You basically need to measure at-rest amperage, between negative post and the car body. Our third gen measured around 20 milliampers, with spikes to 40 every 4~5 seconds, maybe due to the security icon blinking on the dash. To my eye the spikes and blinks didn't seem synched, but who knows.
    If you want to try that, I can go into more detail. @rjparker has a wiring arrangement graphic for this too, a little more elaborate to avoid some issues, as I recall.
  14. ChapmanF
    18,215
    I don't know about gen 4, but in gen 3 there's a convenient squeeze-n-pull plug in a fusebox that accomplishes the same disconnect as undoing a battery clamp, with no wrenches and less fuss.
  15. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
    On a Gen 4, you can use a capable scantool to look at data from the various ecu's. One of them has data for key off draw.
  16. mr_guy_mann
    4,048
    1,974
    NJ-USA
    What was the amount of (key off) current that Toyota measured on your car?
