Is it ok to reverse and put in drive while its reversing?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Syed Ashar Ali, Sep 15, 2019.
  1. Syed Ashar Ali
    Syed Ashar Ali Junior Member
    77
    Houston, TX
    2014 Prius c
    I have a habit that i do often and was wondering if its harmful to car. When i reverse out of a parking space and while its still reversing i will quickly put it on drive . In other words, i dont really come to a complete stop. I just put it in drive while its on reverse. If that makes sense
    49,401
    up to a couple mph, sure
  3. Syed Ashar Ali
    77
    Houston, TX
    2014 Prius c
    Is there any longterm problem doing that
    49,401
    no, there's no mechanical linkage
  5. ChapmanF
    15,508
    The car doesn't mind a bit. You're just reversing the torque on an electric motor; it will smoothly slow you in the direction you were going and continue to accelerate you the other way. Same for shifting from D to R.
    Above a certain speed, 6 or 7 MPH, the car will instead double-beep and shift to neutral. That doesn't harm the car either, and it isn't even done because the shift would be harmful to the car, but more because at higher speeds it makes sense to wonder if it's what you really intended.
  6. Syed Ashar Ali
    77
    Houston, TX
    2014 Prius c
    Ok well i noticed if i reverse and suddenly put on drive without stopping the car runs less smoothly and just overall shakes. If i reverse then stop and then do drive, the car runs so smooth.
  7. bisco
    49,401
    then i wouldn't do it
  8. Mendel Leisk
    38,664
    I've done it occasionally, just around 1~2 mph as @bisco says, but I try not to.
  9. ChapmanF
    15,508
    I've never noticed that when I do it. Maybe there's some other issue with your car.
  10. GasperG
    GasperG Senior Member
    1,168
    598
    Slovenia
    2018 Prius
    At slow speeds regen is disabled and friction brakes are used, but if you shift from R to D when moving, then motors are essentially doing just that, regen at very slow speed. Don't know if it does any harm but that is the fact.
  11. Leadfoot J. McCoalroller
    7,140
    6,688
    Pennsylvania
    2018 Prius c
    I imagine that the gas engine starting-while-rolling-backwards reduces the starting impulse somewhat. If there’s an additional factor (old spark plugs, dirty throttle body etc) that could make for a shaky engine start, maybe you just found a way to expose that symptom a little earlier than usual.
    vvillovv likes this.
  12. ChapmanF
    15,508
    There is a difference, either subtle or glaring depending on how you look at it.
    During regen braking, the M/G is acting as a generator. It resists the motion and slows the car because it is converting the car's momentum into electrical energy to be stored in the battery.
    When you switch from R to D, the M/G is acting as a motor. Electrical energy is being fed into it (in the "go forward" direction), causing it to first slow the car's reverse motion, then accelerate it forward.
    The friction brakes take over from regen at slow speeds because the amount of power the generator can put out depends on speed, and is piddly down at 1 or 2 MPH, so it can neither recapture much energy nor slow the car much.
    Of course there's no such limitation when the car is pouring energy into the motor; indeed, the high torque available from the electric motor at low speed has for years been the thing that's always talked about even by people who hate everything else about hybrids.
  13. vvillovv
    vvillovv Senior Member
    3,616
    1,273
    NY
    regen efficiency is dialed in really well in the Prime. But there are limits of speed to efficiency at both hi and low speeds. Obvious?
  14. Tha_Ape
    Tha_Ape Active Member
    271
    161
    Washington, DC
    I've tried to make myself come to a full stop. This is the first automatic ive owned in my life so it's taking some getting used to.
    I can't imagine it's good to shift into D while rolling backwards. At best, it does nothing, but I err on the side of caution and just stop.
    That said, I did it all the time in the other cars ive owned (manuals) and never had to replace a transmission
  15. fuzzy1
    10,166
    I also sometimes do it at the same very low speeds as on manual transmissions, which still make up 2/3rds of my household's stable. Of course it means slightly more clutch wear on the MTs, but when the speed is very small, so is that extra wear. And we also have never had to replace a transmission or clutch. Even on the spouse's daily driver, which I bought new for her just over 30 years ago. Though it is only just closing in on 200k miles, not a household distance record.
  16. ChapmanF
    15,508
    Compared to the transmissions in other cars, the one in the Prius contains literally nothing subject to damage from doing that.
  17. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    I seem to recall an earlier discussion about this. Somebody actually tried it at various speeds. It worked up to a limit, and above that the car just went into neutral. There aren't any gears changing, only power to electric motors.
