Is it possible to easily check the transmission fluid level?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Feb 2, 2019.
  1. Preeeus
    Preeeus Member
    258
    60
    Is it possible to easily check the transmission fluid level on the 2010 Prius?
    Or is the only way to do it to take the bottom plastic shield off and then unscrew the fill valve and stick a gloved finger in the fill valve?
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,692
    1,737
    Bay Area
    Only way is to do the second option. There’s no dipstick so yeah...
    Preeeus likes this.
  3. Mendel Leisk
    41,062
    I've changed it 3 times. After the first time, I followed the Repair Manual instruction, which said recheck about a day later.
    Which was the hard way: jack it back up again, front AND back, check for level by taking off the fill bolt (I believe you can do this without engine shield removal? But I probably did anyway, if I recall correctly...), and feel with a finger.
    I've never had the inclination to do another check after that. I think if you got the level right, the bolts are installed right, and you're not seeing any leaks, it's fine.
    Preeeus likes this.
  4. Preeeus
    Preeeus Member
    258
    60
    Thank you. We LOVE your videos BTW. Keep on making them!
    NutzAboutBolts and Mendel Leisk like this.
  5. NutzAboutBolts
    1,692
    1,737
    Bay Area
    Thanks! We will do one if there’s anything new happens.
    Preeeus, Mendel Leisk and Raytheeagle like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    I’ve got an inverter water pump and fuel pump lined up :).
    Preventative maintenance of course;).
    Could be the next round for you (y).
    xerox6135 and NutzAboutBolts like this.
  7. NutzAboutBolts
    1,692
    1,737
    Bay Area
    lol, what happened to your guys filming crew? Didn’t you have a youtube channel you guys posted before?
    Raytheeagle likes this.
  8. Raytheeagle
    11,265
    15,518
    2019 Prius Prime
    We aren’t professionals and purely amateurs:cool:.
    Not good quality:(.
    @Rebound said it was too bouncy:whistle:.
    So we need to leave it to those with great equipment and abilities (y).
    NutzAboutBolts likes this.
  9. NutzAboutBolts
    1,692
    1,737
    Bay Area
    Lol I just use a tripod, I think that’s what you guys need
  10. Raytheeagle
    11,265
    15,518
    2019 Prius Prime
    Tripod is fine for most things;).
    But fine details in the engine bay require better views and I ain’t got a great camera:(.
    But we know who does(y).
  11. NutzAboutBolts
    1,692
    1,737
    Bay Area
    Haha, yours waiting in the cart on bhphotovideo ;)
  12. Mendel Leisk
    41,062
    Great store.
