Is it possible to retrofit Gen III Prius with back up cameras or other accident avoidance gear?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by kgall, May 14, 2014.
  1. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    So, I backed up and sideswiped a tree. It was really stupid and my fault, but at the moment of impact, the tree was in a blind spot. It's been fixed, but the cost to the insurance company (well over $3K since damaged a bunch of panels) will probably increase my insurance costs.
    Now, my wife, who has always hated the bad rear view of the Prius even more than I do, thinks I should get rid of it. I'm not ready to.
    But, if I could get back up cameras and/or other accident avoidance systems retrofitted to the thing at reasonable cost, I would consider that.
    Has anyone done this? Anyone know if there is good stuff on the market to do it?
    My car is one of the earlier 2010 Prius II's--the basic model of the first year, if that matters.
    Thanks.
  2. c4
    c4 Active Member
    607
    51
    When I got my 2001 Classic, I came from a 1990 Corolla, which had easy visibility all around: I knew exactly where the hood and trunk ended, I could see relatively easily in all directions, to a new vehicle which had a much higher trunk/smaller rear windshield and a sloped hood, and initially, I simply could not tell how far I was from anything at the front, and I couldn't see anything at all out the back, and all the big headrests, etc impaired visibility all around..
    I eventually got used to the car enough that I knew where the front ended even though I couldn't see the hood, and by moving the passenger seat forward and removing the rear headrests, I improved some of the visibility, but this still did not address the issue of the high trunk lid and small rear window resulting in poor backwards visibility.. I ended up installing an ultrasonic backup sensor (stick on the centre of rear license plate frame, run the wire up into trunk lid through license plate illumination lamps, connect power to reverse light, run wire into cabin to the beeper module, which I painted gray to match the interior upholstery and stuck to the headliner just in front of the high-mount tail light). This was quite effective for anything directly behind me but didn't do anything for the corners, which I had to rely on the side mirrors for (they do sell kits with multiple sensors now, but these all require drilling holes in the bumper, which I didn't want to do), but it did save me from a few bumps..
    I also did get a rearview camera module, and even sourced a module from Japan that allowed you to display the image on the Prius MFD, but the camera required drilling a hole through the trunk to install.. I did try it out by mounting it on a temporary bracket just inside the rear window, but I found that it didn't give me much more information vs. the ultrasonic beeper, so I ended up just pulling it out (I did use the MFD module to direct composite video from a aftermarket Pioneer in-car DVD GPS nav to the MFD display though)
    Nowadays, there are wireless license-plate frame cameras that don't require much to install, but again, I question their real utility..
    kgall likes this.
  3. frodoz737
    frodoz737 Top Wrench
    4,665
    2,490
    33
    Any car audio shop can do these mods for you, so shop around. Unless you change out the HU (Radio), the display for the back-up camera is usually on a replacement rear view mirror or other remotely mounted screen. Back-up sensors with an audio only warning can also be added easily. I added a camera as part of a complete audio upgrade to my 2010 Prius II.
    frodoz Stereo Upgrade | PriusChat
    kgall likes this.
  4. engerysaver
    engerysaver Real Senior Member
    426
    132
    Tyler, Texas ; USA
    Sorry to hear about your accident!!:(
    Have you done your upgrade?(y)
  5. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    I installed an aftermarket camera and a mirror which has a display from the camera feed when the car is in reverse. I had a lot of small children in the neighborhood at the time (they've grown now) but, it's handy for backing into my parking spot at work without hitting anything.
  6. ursle
    ursle Gas miser
    1,049
    192
    NH
    Parking Sensors | Reversing Sensors
    My 13 f-150 has proximity sensors while backing up (as well as a camera) and they make it difficult to get within 4' of anything, the link offers options, camera's are great, but then you're watching a camera instead of your mirrors, true, the camera is great for the last few inches but not so great at five or ten feet.
  7. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I installed the backup camera which integrates nicely with the 6" screen on the stereo. It makes a nice supplement to the mirrors. I find that I'm able to back up safely with a scan of the side mirrors and the camera.
    If you're wife wants to get rid of the car then rearward visibility may be just an excuse. Try asking what she wants instead. If she's quick to answer then my guess is that no amount of modding is likely to satisfy her.
  8. kgall
    kgall Active Member
    984
    152
    I take her at her word--she has what she wants, a 2012 Audi A-3 TDI, red. But when we are in the Prius, she really hates driving because of the visibility.
    Dylan Doxey likes this.
  9. kgall
    kgall Active Member
    984
    152
    Not yet.
  10. Wandering Elf
    Wandering Elf Junior Member
    28
    Perth, Western Australia
    I wonder if anyone has retrofitted a 2009-2011 base Prius with a 2102+ base touchscreen (which includes reversing camera view, but not navigation)? Here in Australia we only get 2 levels of Prius: base and "itech", although I have seen a 2009 Gen3 with navigation/reverse camera and parking assist (I think), but not dynamic radar cruise control, headlight washers, moonroof, or solar panel, and no itech badge on the rear hatch. I guess its a base+navigation pack - its the only one I can find online, so seems very rare.
  11. Wandering Elf
    28
    sorry, I meant 2012+ touchscreen. The 2102 Prius will be pretty Awesome ;)
  12. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Installing a wireless back up warning proximity radar alert system today.
    $21 at Amazon.
