Is it safe to fill up when car is ON?
Discussion in 'Gen 2 Prius Fuel Economy' started by zenMachine, Jun 13, 2007.
  1. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I wouldn't leave a baby in a running car under any condition. Just open the window, shut off the car, gas and go. The tank on the Prius is so small, that it fills faster than any car I've driven. Every station I've ever seen has some kind of roof, to shade from sun. The five minutes it takes to re-fill shouldn't be any big deal if the windows are open.
  2. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    <div class='quotetop'>QUOTE(sparkstack @ Jun 13 2007, 10:10 PM) [snapback]461319[/snapback]</div>
    Sarcasm != logical discussion. :p
    <div class='quotetop'>QUOTE(IAO @ Jun 14 2007, 01:56 PM) [snapback]461774[/snapback]</div>
    It's called minimizing risk. Having your car running while pumping gas does not cause it to explode. <_<
    <div class='quotetop'>QUOTE(Swanny1172 @ Jun 14 2007, 02:15 PM) [snapback]461789[/snapback]</div>
    Wrong. I've seen more race car drivers catch on fire than people at gas stations.
    Additionally, I HAVE been in attendance when a gas station exploded and burned to the
    ground. It was due to a car backfire.
    But as I said before, go ahead and leave your car running if you want to. Natural selection
    should take care of the rest. :blink:
  3. Swanny1172
    Swanny1172 New Member
    666
    Well, Patrick, since you have seen a race car and a gas station burst into flames, perhaps you are a carrier of bad luck. So, it seems that natural selection is already taking its course. :lol:
    BTW, was the car that was being refueled the one that burst into flames due to the backfire? How exactly did it burst into flames -- was there gas on the ground? I need more details.
    Finally, your experience is purely anecdotal. It means nothing more than my experience of never seeing a gasoline fire caused by a car running during refueling.
  4. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    Half of the times when people say "just to be safe" means my fear overcomes my logic.
    Fear is a powerful emotion and is evolutionarily conserved. The power of humans to comprehend and use logic is at war with fear however I still have an irrational fear of heights.
    It's a balance for every one of us.
    Patrick is afraid to leave his car on and wants to rationalize his fear. What's the big deal? People rationalize millions of things from god to war to anything...
  5. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    <div class='quotetop'>QUOTE(subarutoo @ Jun 14 2007, 02:38 PM) [snapback]461810[/snapback]</div>
    I don't disagree, although in the Prius' case the car is not really "running" (unless the ICE kicks in if the battery runs down, which is unlikely if it only takes a few minutes to fill up that bloody bladder). And if it does get too hot, I'll just do the OFF-ACC-IG/ON dance to get the A/C running again.
    What I hope to avoid is turning off the DVD player that's plugged into the console 12V, because it doesn't have the restart-where-left-off function. But, for safety's sake that's not that big of a deal, and the baby doesn't seem to mind too much anyway - and even if he does, he'll just have to learn to live with it... :)
    Come to think of it, maybe I do need to add an always-on 12V mod after all...
  6. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Time to point out a few mistakes in some of the thinking.
    1) Where does it end? If I don't turn the car off, do I have to set the parking brake? No rule there. Do I have to put it in Park? No rule there either. Do I have to remove the key? No rule there. Why in fact, it does not even say the car has to be stopped. It never occurred to me that turning off your car would be questioned so vigorously.
    2) Leave the car on..... The baby will eventually become a toddler and then a kid. One day with the car on and the parking brake not applied, the kid will take that fun lever that everyone always grabs and pull it up or down. Assuming nothing disasterous, the next time the parent will pull into a gas station, set the parking break, turn off the car, get everyone out,...and then put wheel chalks all wheels before filling up.
    3) Fuel lines crack, electrical lines fray, the driver behind you may inadvertently bump your car while refueling, causing who knows what to happen. (In that case it is entirely his fault and my car running is of no concern?)
    4) When the Prius is off the HV voltages are disconnected from the cars HV wiring and inverter.
    5) Most Gas Station pavements are soaked with gas.
    6) But most important to me is that I consider other peoples safety before my convenience. Thanks to all out there that do the same.
    Please set the parking brake, put the car in park, and turn it off. If you have a kid or baby, also remove the key, this locks the transmission in park, keeping your kid safer.
  7. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    Turning the vehicle off while refueling is all about risk mitigation. Will the car explode or catch on fire? Under ideal conditions probably not, but if something goes wrong it will give you a safety buffer. Is the risk worth the possible consequences? If the 1 in 1 billion chance something goes wrong and someone gets hurt what would you say? "oops sorry did not think that would happen. Tough luck you got hurt."? Would you take that as an answer if someone did it and you were the victim?
  8. just_marci
    just_marci New Member
    49
    <div class='quotetop'>QUOTE(zenMachine @ Jun 13 2007, 06:35 PM) [snapback]461175[/snapback]</div>
    Oh FFS...what are we talking about here - five minutes? At most?
    Turn the car off. Five minutes of Precious being ever so slightly uncomfortable is far less than going boom.
  9. M1Prius
    M1Prius New Member
    It takes less than 5 minutes to pump and pay for gas, so I think you and your baby can survive with the car off. In addition, all gas pumps I know are under the shade and your car should be cool already before your turn it off. A bottom line is that you just need to stop being a diva.
  10. ystasino
    793
    50
    Tucson, Arizona
    I have a 700KB wmv file that shows clearly HOW static is generated... If anyone can host PM me.
  11. patrickindallas
    676
    36
    Vancouver, WA
    <div class='quotetop'>QUOTE(ystasino @ Jun 14 2007, 04:09 PM) [snapback]461847[/snapback]</div>
    OK. How about "just not to be stupid". Does that sound better?
    <div class='quotetop'>QUOTE(ystasino @ Jul 3 2007, 11:42 PM) [snapback]472771[/snapback]</div>
    Static? Like E-mag static? My Mom gave me static once, is that what the file is about?
    The world has known 'clearly' how a static charge imbalance is generated for several hundred years now.
  12. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    I told myself I wasn't going to get into this thread but I couldn't help it. For the record, I DO turn off while I'm pumping gas but I think it's entirely unnecessary. I think it was already brought up before but, what if someone drives into the station while you are pumping gas? Should we quickly button up our tank while the offending newcomer to the station has his engine running? Are we going to go as far as not allowing ANY engines to run within 50-100' if ANYONE is currently pumping gas. How silly would it look for the station to have a sign that read, "Station temporarily closed due to gasoline being pumped."? I think there would be far more danger from static discharge than an engine running in a gas station. Even so, how many station fires have you heard of from static discharge? Sorry for the rant.
  13. ystasino
    793
    50
    Tucson, Arizona
    <div class='quotetop'>QUOTE(patrickindallas @ Jul 4 2007, 01:31 AM) [snapback]472787[/snapback]</div>
    Have you ever watched the caveman ads?
  14. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    I almost never turn off the car when I fill up, so watch for an eventual news report of a horrendous gas station explosion. I'll make sure to take a few SUVs with me :rolleyes:
  15. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    <div class='quotetop'>QUOTE(Presto @ Jul 7 2007, 07:49 AM) [snapback]474615[/snapback]</div>
    I can see the headlines now - Prius suicide bomber takes out SUVs :p
  16. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    <div class='quotetop'>QUOTE(Tadashi @ Jul 8 2007, 11:05 PM) [snapback]475303[/snapback]</div>
    ...and then goes on to point out that the suicide bomber could have done it cheaper in a Yaris. :D
    Tom
  17. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
