Is it the same? Tansmission Fill plug
Discussion in 'Gen 3 Prius Main Forum' started by johnnychimpo, Oct 25, 2021.
  1. Tombukt2
    Tombukt2 Senior Member
    13,866
    2,519
    Durham NC
    Just use the rent message drain the mess I usually go off and pour a coke and stand around a while and just let everything drain and drain drain put the drain plug back in clean the magnet if applicable and fill up with the 3.6 quarts and close the hole and drop it and you're done and that stuff stays in there and in the same a long time I've seen it with 200,000 miles on that fluid and a gen 2 and it wasn't that dark I changed it anyway didn't smell funny or anything
    SM-A715F ?
