Is it time to get solar panels?
Discussion in 'Prime Main Forum (2017-2022)' started by Jnbrown, Feb 18, 2022.
  1. Jnbrown
    Jnbrown Member
    111
    85
    Encinitas, CA
    I have noticed my gas & electric bill creeping up.
    Super off peak electricity is now 31 cents per KWH hear in San Diego which I think is highest in the U.S.
    I got an estimate maybe 5 years ago when I bought my Prime and it was about $7K for solar panels.
    I figured it would take me 7 years to break even and decided not to go ahead.
    My utility SDG&E is now at 40% renewable energy so that is also a consideration.
    Another confounding factor is utility companies keep wanting to charge more for those with solar panels making it less attractive over the long term. I am 64 so not that many years left to amortize the cost of solar panels.
  2. fuzzy1
    10,720
    Yikes:
    https://tariff.sdge.com/tm2/ssi/inc_elec_rates_res.html
    Have you done much in the way of conservation? I started my DIY solar installation 9 years ago, expanding to net-zero 2 years later. But significant energy conservation efforts to my all-electric home started 16 years ago, and ended up cutting total energy to just half of what it used during the 1990s. This also halved the solar capacity needed to reach net-zero.
    Conservation measures included updated appliances, numerous building envelope improvements to improve insulation and infiltration, and improved management of solar heat gain. In my climate, the later mostly means maximizing winter solar heat gain to offset space heating. Though it also meant creating shade over a sliding patio door to keep our several days :) of intense summer heat from flooding in through the glass. The solar panels also partially shade the roof, reducing attic temperatures and the amount of heat radiating down into the living space.
    We actually had some surplus solar capacity. I had intended to use that surplus (along with some more added solar modules) for a future PHEV, but laziness and lack of travel during the pandemic caused our energy use to creep up enough to consume that surplus. When a plug-in vehicle finally arrives and we need to start purchasing electric energy again, I have several other conservation upgrades in mind to help reduce it.
  3. RovinRon
    RovinRon Junior Member
    33
    22
    Federal Way WA./Sun City AZ.
    Wait a minute!! I'm 81 and still going strong!! We put them on our winter home here in AZ several years ago and we will be caught up within the next 3-4 years. At the time we we got them, it made more sense for us to buy, but you need to check that out for todays deals. I would say go for it!
  4. yaun
    yaun Member
    72
    65
    MA
    Do it, 64 years is young and 7 years till breakeven is really good. I assume California has net metering?
    I got an 8kW system last year. In terms of suitability for solar Massachusetts is of course much worse than CA and I also have some trees shading the morning and evening sun. My system is predicted to have paid for itself after 10 years with a conservative assumption of a 3% yearly electricity cost increase. The system is warrantied for 25 years and after 20 years I will have made 100% profit, that's a safe 3.5% return, much better than government bonds with their negative real yields that you'd likely own in a retirement portfolio tailored for your age.
    Apart from federal and state tax subsidies, the biggest subsidy is net metering. Here in MA it's 20 years guaranteed for the utility to take my excess energy at the same rate that I have to pay when they deliver to me. Since I don't have to build a costly infrastructure for transmission and base load guarantees, that's a stunning subsidy that is basically paid by other electricity customers. Since more and more people are getting solar, expect the costs for that to rise, further putting upward pressure on the electricity price until at some point this subsidy will have to stop for new customers.
    #4 yaun, Feb 18, 2022
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I'm 68. I put in solar last spring. If my rates were as high as yours, I'd have done it a long time ago. Well, actually, I would have moved. :D
    Merkey likes this.
  6. Jnbrown
    Jnbrown Member
    111
    85
    Encinitas, CA
    I am having somebody coming to give me an estimate.
    If it is $10K or under I will probably go ahead.
  7. jerrymildred
    11,517
    14,171
    Tampa, FL
    For how many kW? $10k won't get you much.
    Mine was about $3.38 per watt before the federal tax credit. If your's is similar, $10k would only get you about 3 kW. But with California prices being what they are, that seems optimistic. But then you folks get all sorts of rebates to give you back some of the money the state takes away if you play nice with them. And there is still the 26% federal tax credit. That dropped my price to about $2.50/kW.
  8. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    Best time to get solar is always 10 years ago
    jerrymildred likes this.
  9. jerrymildred
    11,517
    14,171
    Tampa, FL
    Yup!!!
    Second best time is now. ;)
  10. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    You should read this before investing in solar in California at this time. I'm not sure it's too late, but solar could become not a good investment in the near future. MIKE KLEEMAN - Blog
  11. Rmay635703
    2,704
    1,730
    2013 Chevy Volt
    The #1 thing that is and always was needed is a legal right at the federal level to be “off grid”
    The Amish are generally allowed to be off grid even in areas that ban being disconnected from electric.
    By allowing you a guarantee to be off grid you then have choice and leverage over bad policy
  12. fuzzy1
    10,720
    You haven't said how many kWh per year you use, or the size of system you want or would aim for. Without those, we can't make any cost judgements.
  13. jerrymildred
    11,517
    14,171
    Tampa, FL
    Everyone has the right to be off grid and always had the right. Apparently not all states honor that right.
  14. yaun
    yaun Member
    72
    65
    MA
    Being off grid in New England in the winter on solar alone sounds like a truly Thoreau'ish experience though.
  15. Rmay635703
    2,704
    1,730
    2013 Chevy Volt
    Glad I have wood and a corn burning furnace
  16. MikeDee
    1,581
    597
    Be careful, you don't want this to happen when burning corn
