Is it time to hang this car up?
Discussion in 'Gen 2 Prius Technical Discussion' started by vdubstress, Mar 22, 2019.
  1. vdubstress
    vdubstress Junior Member
    47
    So I was making a left turn this week and got the dash Christmas tree effect. The shop is saying new hybrid battery and hybrid system pump to the tune of almost $3k. Worth it at 187k? Or is it time to out the Prius out to pasture?
  2. Leadfoot J. McCoalroller
    8,249
    7,753
    Pennsylvania
    2018 Prius c
    1) are they quoting you a genuine Toyota replacement battery?
    2) do you really, really like the car?
    Less than two "yes" votes = time to say goodbye.
    52,725
  4. vdubstress
    47
    Yeah, the shop said they will only do a new Toyota replacement. The car runs beautifully otherwise, I've owned it since it was new and it really doesn't feel like 12 year old car.
  5. bisco
    52,725
    sounds like a plan. the longer you keep it going, the better for everyone.
    vdubstress likes this.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    vdub, where are you located?
    Also curious about what 'intake air screen' they are speaking of. Since I have yet to see one of those on any HV battery I've worked on............
    Raytheeagle and SFO like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    What was the oil level?
    Skibob likes this.
  8. padroo
    padroo Senior Member
    2,763
    2,253
    If the engine is showing signs of heavy oil usage and it needs a battery I would let it go. It is a big financial decision one way or the other.
  9. vdubstress
    47
    I'm in the Sacramento area. Not sure about the screen. I did go to grab my daughter's car seat (named tank) and noticed the vent area is linty/kinda gross looking.
  10. vdubstress
    47
    I'm usually adding about 1/4th a quart St every fill-up, so about 1 quart every 1200-1500 miles. We've had a lot of wet, cold, windy weather, so the defrost, heat and AC have been running pretty much since November. I'm still getting about 48 mpg.
  11. vdubstress
    47
    Just below the top dot on the stick.
  12. padroo
    2,763
    2,253
    It sounds like you keep a good eye on your oil level. A lot of people don't and wait till the light comes on and wonder why they have problems.
  13. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Might be worth investigating the battery fan if it hasn’t been cleaned before ;).
    Do you ever hear the fan running?
    Good luck and keep us posted (y).
    SFO and Leadfoot J. McCoalroller like this.
  14. vdubstress
    47
    I rarely hear the fan, only when it is very hot here in the summer
    Raytheeagle and padroo like this.
  15. bisco
    52,725
    hearing it and cleanliness are two different things
    vdubstress and Raytheeagle like this.
  16. padroo
    2,763
    2,253
    I've owned two Prii and never heard the fan run but hearing isn't one of my strong points.:)
  17. Autumnbear22
    Autumnbear22 Junior Member
    Buy a rebuilt battery or replace the bad cells in your battery yourself. I did mine and I’m a 66 year old gramma. You tube videos are amazingly full of information. It’s not that hard if you follow directions and have some muscle. I did have tools available.
