Is it time to move on ? :(
Discussion in 'Gen 3 Prius Main Forum' started by Kiiing, May 31, 2026.
  1. Kiiing
    Kiiing Junior Member
    Brooklyn, NY
    I have 2013 Prius II. I've had the car since 2015 with 39k miles. I recently hit 190k miles. I just changed the water pump a 2 months ago and immediately after I had to do brakes, rotors, and 1 caliper. Now the brake system has gone haywire. The car needs a brake booster and master cylinder replacement. From what I'm seeing this is a $2000 repair on average. Is it worth it to keep pouring money into this car or just move on? The car also needs a 12v battery. I'll be honest I have never been the best with maintaining the car. I recently found out about having the EGR and haven't gotten that done yet. I checked Dr. Prius and it shows the battery level to be at 60%. Not heavily, but the engine also burns oil. I'm just trying to get some insight to make a decision. Thank you
  2. JC91006
    16,936
    8,647
    There will be at least 3 expensive failures on this car. All of them will average $2000 or more. So if you’re not prepared to throw $6000 or more into this car, it’s best you don’t invest in this repair. If you have the means to get a newer car, that would be best
    PrimeDan likes this.
  3. Kiiing
    Brooklyn, NY
    What are the 3 repairs? I'm assuming one is the battery and the other is this one I currently have to do. Maybe I can get an idea from a mechanic where I am with having to do those. I can manage them one at a time possibly, but I'm also on the fence because what if the engine or transmission decides to go after everything. I'm really trying to avoid having a car note
  4. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    Some enjoy painting a horrible picture because they had issues so they want others to
    suffer like them so they can feel better... EVERY car has issue and parts and labor are expensive.
    If you are able to do the labor part the cost is about 75% less.
    The head gasket, hybrid battery, and possibly brake master cylinder and pump actuator can be
    expensive.
    I replaced my hybrid battery about 2 years ago with the lithium then sodium ion pack. Fairly easy job
    to do. I replace the head gasket at 301,000 miles. I had planed on replacing it before it went. Not knowing
    just how long it would before it did fail so I already had 95% of the parts I needed and was just choosing a
    date, so it wasn't a disaster for me. It wasn't too difficult of a job.
    The brakes are still going. Though the pump cycling is down to about 17 seconds. So I know it's a matter
    of time before it needs to be done.
    I had been making plans to replace of replacing the brake parts AND the engine with a remanufactured one
    at the same time so that I would have more room with the engine out to replace the brake parts.
    But my driving went down from around 700 miles a week to less than 100. And I've been driving my van
    the one day I week I travel about 200 miles. So replacing the engine is really not worth it just because it's
    burning oil, and I'm driving it 98% of the time in the city so less oil burning.
    I had also though about just doing the short block, but I still need to remove the whole engine. It would be
    a lot quicker and a lot less work to replace the whole thing.
    If you have to pay someone else to do the work, then yes, it is expensive. But what does a new car cost???
    And even a used car cost a lot. And sooner or later you'll have failures on that car also.
    So you'll have to do that math and see figure out financially and time wise what is best for YOU. No what is
    best for someone else.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,101
    6,966
    Texas Hill Country
    Some people who have the tools. parts and experience love to keep old cars. Some value reliability more than short term savings.
    Head gasket $2500-$5000 (higher costs represent engine replacement recommended with oil burning), the Brake Booster issue you have now, Hybrid Battery that everyone knows will happen and Inverter stranding (still covered but very problematic when it occurs).
    You can get into sunk cost syndrome where each repair seems less costly than replacing the car but you end up giving up reliability and costs accumulate. The reality is the car has to be replaced sometime and it will never be worth more than now after the brake booster is replaced.
    If your finances are so tight that a used car payment is impossible, you do what you have to do and hope the interval between repairs is decent. In that case it is wise to find an independent hybrid shop that offers value solutions and build that relationship.
    #5 rjparker, Jun 1, 2026
    Brian1954 likes this.
  6. ETC(SS)
    7,555
    Depends on what you replace it with, and where you live.
    If you replace a car with $0 monthly purchase payments and the possibility of an eye-watering repair every year with a much newer car you may be out significantly more money.
    According to Robbie the Robot, the average monthly payment for a used car in the U.S. is $537 which is a number that begs to be rounded up to $6500 a year.
    WITH no repairs - remember, we're talking about a USED car, that somebody who is NOT YOU got rid of.
    If you live on free soil - that's nearly as bad as it gets, but if you live in 'some parts of the nation' other 'expenses' like inspections, excise (tag) and sales taxes, and added insurance might add to that additional cost.
    It's not just a red-state versus blue state thing.
    Blue states come with higher regulation and tax burdens, while red ones come with more weather related insurance costs, and a higher number of people who flout mandatory insurance laws and sometimes a lower number of state mandated driver's ed laureates.
    You're about a 15k per year driver according to your post.
    Maybe it's time to 'get better' at maintenance and repair - or maybe it's time to roll the dice with a newer car.
    Car buying is not straight out math, so you're going to have to do the noodle dance on this one for yourself.
    Good Luck!
  7. JC91006
    16,936
    8,647
    Others have chimed in on the 3 repairs. But this car has other issues beyond those. Since you live in NY, the rust is probably a problem as well. 11 year old car in NY with rust and probably bad paint. You'll have to decide if it's time to move on. Sunk cost is never a reason in making your decisions in life, once the money is spent, it's gone. So if you throw money at the brake actuator now, it's just buying time before the next repair comes (and it won't take long on a 11 year old 3rd Gen Prius). End of the day, no matter how much you throw at this car, the next repair won't be far behind.
  8. bisco
    52,855
    dump it before the engine blows. that's gonna total it
  9. Alexikor
    Alexikor Junior Member
    38
    Arizona
    there is likely no car of comparable history and reliability for less than $6000 than your 2013 prius which you've owned for past ~150k miles. in its current state, your prius is maybe worth $0-2000 on the used car market--financially totaled but still viable as transport especially if the interior is in a pleasant condition like working windows, working AC, upholstery in good condition, no cracked or scratched plastics etc.
    likely all cars at that price range (opportunity cost of $6000-8000) likely have a comparable number of miles, are of similar age (therefore potential rust/weather exposure) and harbor far more unknowns. sure you might get lucky and find that the little old lady at the end of the block is selling her car she bought new, always garaged, never driven in winter yadda yadda, but finding that type of deal will mean watching craigslist/fb marketplace/autotrader like a hawk.
    if your budget (assuming cash, please don't make the mistake of financing a car) is substantially greater than the opportunity cost (eg $14,000-16,000), then it might make sense to sell and buy a something with less wear and tear. perhaps there are dealership specials in NY as there are in AZ where a dealership will "buy any car for $3000" and you could try getting them to buy your prius. otherwise i'd keep the car and get all the repairs done. you will be hard-pressed to find anything cheaper that's as reliable and familiar to you.
