Is it worse to keep battery full overnight or empty overnight?
Discussion in 'Prime Main Forum (2017-2022)' started by panpaper, Oct 24, 2018.
  1. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    The regular Prius is usually kept around 80% of 80% though. Whereas the prime is much more variable, which I think is what is contributing to my extreme capacity loss as my car is usually kept at 10% of 80%.
  2. Tideland Prius
    16,683
    No. The chemistry is different. The ones for the Prius are designed to be charged and discharged frequently with a more varied range of charge level (having a small SOC range doesn’t help either).
    The Prime’s chemistry is designed for fully charging then discharging and then fully charged again.
  3. padroo
    padroo Senior Member
    2,763
    2,253
    I found this statement backing up your information, thank you.
    The cell chemistry between the two is different (the regular Prius requires more durable and power dense batteries, while Prime more energy dense), as well as the number of cells, but overall engineering seems similar.
    Disassembly And Breakdown Of The 2017 Toyota Prius Li-Ion Battery Video
    Tideland Prius likes this.
  4. Tideland Prius
    16,683
    Yay.
    padroo likes this.
