Is it worth replacing the rear large-windshield glass on 2007 Prius myself?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, May 6, 2025 at 8:56 AM.
  1. priuslyfe
    priuslyfe Member
    180
    42
    I have several 2nd Generation Prius parked in my backyard. There were storms over the weekend and a branch must've fell and broken the large glass on rear of my 2007 Prius.
    To pay for replacement its around $300, but I'm considering going to a salvage-yard and trying to pull the rear-glass which will cost somewhere between $20 to $50. I know that is a job that is much more difficult or prone to breakage unless you do it very carefully/luck out. Not to mention the install of the new window.
    Would rather have OEM glass rather than risk getting a cheaper Chinese-made aftermarket glass. BUT on the other hand seems like a big hassle and I could end up breaking the glass anyway. Does the glass really matter if its the back-glass anyway?
    Thoughts appreciated.
  2. Tombukt2
    Tombukt2 Senior Member
    11,616
    2,054
    Durham NC
    So how many generation 2 Prius have you seen with fake back glass pieces? I don't think I've ever seen one personally I don't generally look all the time I look at the front glass 90% of those have been replaced but the back generally not so much is it easy to replace pretty much by the way I find to take windshields and back glasses out is to use a multi-tool with a blade that I buy online that's made to cut through the urethane where the glass is glued in front and rear the blade is about $24 it goes on your multi-tool it's extra long it's kind of like a scraper and you just stick it in between the metal and the urethane and the glass and hit the button and it just undoes the seal between the urethane glass in the metal if you go to the glass shop you'll see the glass shop people use a tool that looks like a sawzall with the blade I'm talking about they make the same blade to go in a multi-tool if you don't want to buy the sawzall looking thing or if you own a sawzall you can get the same blade for the sawzall the solves all is a little more to control then the multi-tool the multi-tool you can operate with one hand the Saw's all not so much then again you got to remember the glass place is cutting out your broken glass so it's already broken they're not trying to save what they're taking out you are the multi-tool is not quite as hard on everything if you can understand that the sawzall. Make some serious vibration when you're cutting the glass out the multi-tool not so much
    priuslyfe likes this.
  3. priuslyfe
    priuslyfe Member
    180
    42
    thanks. do you have a link or picture of what this tool looks like?
    I've seen some videos of people using heavy-duty plastic knives to cut around the glass and was thinking about buying one. basically you tap it inbetween the glass and hatch and slowly cut it out.
    I just put a thick blanket over it for now as its been raining basically all day everyday for the past few days because of the storms. its also supposed to rain all day today so I'm not exactly in a rush to work on it.
  4. Doug James 65
    Doug James 65 New Member
    Clermont, FL
    The hardest part would be removing and transporting the glass without breaking it. The other problem is the adhesive to reinstall the window on you car. There is a special automotive silicone that is used for this, and window installers have a powered gun to put this around the window fast and place the window before the adhesive starts to set up. That would be hard to do at home by yourself.
  5. Tombukt2
    11,616
    2,054
    Durham NC
    No a knife will never make anything happen except break the glass I can't even imagine I used to work in a salvage yard and have to do this there's a tool that they make that has a little side handle and an angled blade and an aluminum handle if you want to go the seriously manual route but usually that takes a long time and the chance of breaking is about 85%. I used to have to pull these in a salvage yard situation years ago like 1985 when the Cadillac had the plastic inside lined windshield that everybody screwed up putting inspection stickers on
  6. Tombukt2
    11,616
    2,054
    Durham NC
    I'll try and get you a link up for the blade but you can just kind of Google it windshield removal blade for a multi-tool I kind of looks like a big scraper or a scraper that goes on a multi-tool but it's longer so that it can reach down between the top of the dash and the windshield I mean obviously but I'll try and get you a physical link to the exact bit that I buy from the same seller that I purchase it from as soon as I can get to my main computer. The knife you'll wind up cussing out everything in sight and never looking at a piece of glass again that's for sure the multi-tool or the sawzall looking device makes it almost the one handed job seriously. With the multi-tool and the sawzall in the glass shop they don't even have to pull the trim around the inside of the windshield this tool reaches down that's why it has to be long it was right in between the dash all the surround plastics up along the top edge none of that has to come off you just stick this tool in there and pull the trigger and follow the line that you started whichever way you're going generally a windshield will be out and about 14 minutes something like that.
  7. priuslyfe
    priuslyfe Member
    180
    42
    thanks for doing that.
    thing is ...is it even worth trying to replace myself? Salvage yard said if they have one I have to do it myself (they only remove door windows for customers). Salvage yard guy said it takes some people 1 hour and others 3 days so no tellin' how long it will take.
    I heard that the OEM glass/better-aftermarket offers better sound-insulation and shielding. I suspect that most low-cost window replacement guys use the cheapest aftermarket but one told me if I can bring in the glass ...he'll install it for $150 (if I can't do it myself; honestly that seems not possible - I can see myself breaking it and flipping out). He said, a new OEM would cost over $1000 installed by a dealer.
    So is it worth trying to go to the salvage yard and salvage this situation or should I just bite the bullet and go to a traditional replacement guy? It seems like its one of those things that are 50/50 in terms of saving time & money IF everything goes perfect by yourself.
  8. PriusCamper
    PriusCamper Senior Member
    11,877
    4,819
    Pacific Northwest, USA
    If you have the tools that auto window glass installers use to remove old windows and install new ones and you've watched lots of youtube or Tik tok to learn how to use those tools, then go for it. But it doesn't take much to damage the glass you're trying to pull because the way they do car windows today is way different than how we did them back in the 70's and 80's.
  9. Tombukt2
    11,616
    2,054
    Durham NC
    If you got the time just amble on over there to LKQ and cut the thing out then what are you going to do to get it all the way across lkq's yard with the little cart just going to lay it on top of the carton start pulling it across the Rock Yard maybe not you probably going to want to bring a U-Haul blanket or something like that with you I doubt you'll have any cardboard that's that size. And when you look at your hatch it should tell you on the glass that it's factory original I've never seen an original I'm sure they exist I just haven't seen one
  10. Tombukt2
    11,616
    2,054
    Durham NC
    MAX2 and priuslyfe like this.
  11. Tombukt2
    11,616
    2,054
    Durham NC
  12. MAX2
    MAX2 Senior Member
    1,391
    454
    101
    Third planet from the Sun
    If you don't have the skills to work with glass, and I believe that many ordinary drivers don't have such skills, the best option is to pay the specialists the amount required. The second option is to find a whole rear door of the required color at a car dismantling site and replace it completely.
  13. Tombukt2
    11,616
    2,054
    Durham NC
    The black urethane from PPG goes in the oven at The windshield shop to have a special box that looks like the milk box that used to get milk magically appearing in it when you were a little kid that has an element in it that keeps several tubes of urethane one time heated I just use my toaster oven and then you generally have plenty of time once the urethane is in the gun and to run a bead around one windshield is not too bad if you had to do 50 a day your hand would be expired after about 12 but yes all of those things with the urethane the heat the curing I don't think will be a problem unless you're just really slow as a turtle you don't have to be as fast as the guy at the windshield shop but he can't have the stuff sitting there for an hour on the frame of the car about 18 minutes is normal. I mean if you fly a desk and things like that then you probably want to start with smaller pieces of glass at first like the ones that go forward of your front windows things like that then you work your way up to windshields and back glasses I guess
  14. Leadfoot J. McCoalroller
    7,768
    7,246
    Pennsylvania
    2018 Prius c
    I've seen plenty of low quality aftermarket parts. Some were obvious counterfeits and others were only just a little lousier than the OEM.
    ...but I don't think I have encountered much variation in auto glass across sources.
    Specifically relating to sound insulation: There are some situations where the car is built with laminated glass in a side window, which is wonderful for noise control. But the same window is also available as tempered safety glass, which is much cheaper and does not block as much noise. Sometimes that would have been from the factory on a lower-trim version of the car.
    It is usually possible to install the cheap version in cars that were originally equipped with the expensive windows. Perhaps this is what you're referring to?
    The good news here is that the back window of your Prius was always made with tempered safety glass. Nobody ever made a fancy version of it.
    To sum up, I think you have unfounded fears. Just go to the local window shop and let them do their thing.
  15. highmilesgarage
    highmilesgarage Active Member
    411
    148
    Kansas City
    I've tried replacing the windshield on my Prius a long time ago, 1st time it cracked during transport.. luckily junkyard will accept returns and replacement. I just used a string type remover from Harbor Freight.. lots of work but it worked ok.. the knife if you're not careful can break the glass while removing (did that on several Prius while in the junkyard) The other thing when installing is that you need a pneumatic caulk gun to apply the sealant. A manual gun will make your arms sore.. with all the tools and materials required, saving maybe a $100 is not worth it. Cheaper to just find the whole rear trunk assembly that matches your paint ($40 - $80 depending on the junkyard location)
  16. ChapmanF
    16,997
    That's just what I was going to ask: how much would the salvage yard want to just sell you the whole hatch?
    Tombukt2 and priuslyfe like this.
  17. priuslyfe
    priuslyfe Member
    180
    42
    this might be the way OR I'll just pay a glass replacer. this whole situation makes my head hurt even though it isn't my main Prius. coincidentally, I guess tempered glass breaks very easily so even something small falling on it may have shattered it.
  18. Tombukt2
    11,616
    2,054
    Durham NC
    Here in North Carolina that hats will be 150 to 250 bucks depending upon condition and where the salvage yard is for the most part $80 that's from somebody that has a Prius in their yard
  19. Mendel Leisk
    40,266
    I'd bite that bullet: just because you (possibly) can do something, doesn't always mean you should.
    Tombukt2 likes this.
  20. Tombukt2
    11,616
    2,054
    Durham NC
    I mean if you're at the house and you got a carport shouldn't be any problem really the glass doesn't weigh squat and you're liable to drop it more than anything kind of funny to handle but. You'll want to have some xylene and stuff like that on hand to wipe up any of the urethane that gets anywhere
