Is Mobile 1 High Mileage oil a bad match for the Prius?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Mar 2, 2019.
Tags:
  1. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Old left, new right. If anyone can direct me to a site that will decrease the size of the file I would be thankful!
    Thanks Georgina!!!!! Removed excessively large file....
    #41 jzchen, Mar 4, 2019
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    "High Mileage" oil is ONLY the right choice when you have an engine that already HAS high mileage AND is showing signs of high oil usage too......which can't be explained by leaks.
    I personally would not consider it unless and until you are using more than a quart of oil every 3000 miles or so.
    Even then, it probably will be a temporary fix and a prudent person probably should start shopping for a replacement vehicle.
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Actually, if you started using Mobil 1 BEFORE oil consumption issue started, please call them about it. Would be very interested to see if this is a covered issue which they may help with......
    Preeeus likes this.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,465
    2,432
    Taylors, SC
    Preeeus and jzchen like this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    At about 24k miles, I will ask Mobil when 75k miles comes along, what their opinion is, Annual Protection, vs EP High Mileage....
  6. Mendel Leisk
    41,463
    Be careful what you ask for, lol. The original file was not that big, 700x900 ish pixels. And: you could read it, lol.
  7. Merkey
    Merkey Active Member
    315
    285
    Birmingham, Michigan
    Try Costco online. They carry more weights of Mobil 1 than the stores. Also try Walmart.
  8. sam spade 2
    7,035
    2,803
    2017 Prius c
    You don't "treat" a disease if there are no symptoms.......usually.
    That applies here too.
    If you search around a bit you can find that out now, without waiting another 50K miles.
    NO oil company that makes one recommends a "high mileage" oil for an engine that is showing no symptoms of wear and increased oil use.
  9. Mendel Leisk
    41,463
    I thought they did, actually. I can distinctly remember standing with a bottle in my hand, maybe 20 years back. The message was something like this:
    "Is your car getting on in miles? Then it's time for..."
    They almost had me sold, lol. Absolutely no mention, that it's specifically formulated to swell gaskets, that this was a one way trip, and best left until the car was a knackered oil eater. Nada.
  10. Mendel Leisk
    41,463
    I see no indication, just: "You've got 75K miles? Time for this."
    And on the backside, a vague statement about "seal conditioner":
    Preeeus likes this.
  11. sam spade 2
    7,035
    2,803
    2017 Prius c
    You have been around long enough NOT to expect most any big company to tell the whole truth about ANYTHING ........if there is a potential to make them a few extra pennies.
    I think what you said was true when those products were first introduced.
    Most of them are a bit more careful now.........since there has been some independent input into the appropriate use.
    (Edit) But not all, apparently. I really don't understand why they do that.
  12. ASRDogman
    ASRDogman Senior Member
    7,597
    3,916
    The key is to notice: to HELP prevent... to HELP extend.
    It does NOT say it DOES does either. It would be impossible to PROVE it does neither.
  13. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    That’s a tough one, because prevention, ie. vaccination, has done away with some serious illnesses of the past, ie. smallpox....
    Preeeus likes this.
  14. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Let the roller coaster ride begin.
    Raytheeagle and m.wynn like this.
  15. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Vaccination introduced ADD, ADHA and some other serious illness.
  16. sam spade 2
    7,035
    2,803
    2017 Prius c
    No it didn't.
    Stupidity introduced beliefs like that.
    Brainwashing is not hard when the target audience is highly gullible.
  17. Mendel Leisk
    41,463
    The vaccination paranoia is likely at least partially to blame for a recent rash (terrible pun) of measles in Vancouver.
    We digress.
    HPrimeAdvanced likes this.
  18. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    My previous Toyota was a 1993 Corolla DX Wagon, in which I changed to Castrol GTX (High Mileage) after it started using oil (at about 100k miles). The Castrol worked wonders for the engine as it stopped using oil, but unfortunately it didn't do much for the rocker-panels (sills) which rusted out (NE Winters :eek:), and the car failed the state inspection at about 290,000 miles (21 years) :) (…but the engine still ran perfectly!) - but, as they say YMMV! :rolleyes: ;)
    Preeeus, Raytheeagle and Mendel Leisk like this.
  19. Georgina Rudkus
    3,465
    2,432
    Taylors, SC
    It's common for others to suffer for and pay for the mistakes of irresponsible others.
    WilDavis likes this.
  20. WilDavis
    2,493
    2,155
    49
    That's because we're now living in The Age of Entitlement ;)
    Georgina Rudkus likes this.
