Is Mobile 1 High Mileage oil a bad match for the Prius?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Mar 2, 2019.
Tags:
  1. benagi
    benagi Active Member
    525
    280
    Utah
    Correct
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    The 2010 Prius Warranty and Maintenance Booklet is available here:
    https://www.toyota.com/t3Portal/document/omms-s/T-MMS-10Prius/pdf/2010_Prius_WMG_0W20_lr.pdf
    It’s 10k miles unless you operate a majority of the time under “Special Operating Conditions”. Reference .pdf page #40, booklet page #38. (Definition of the superscript #1).
    The dealers should have replaced the oil at the yearly mark, no matter how little miles you put on the car, or 10k miles, whichever came first. There were posts here that some were able to convince their dealer to change at the 5k mile mark, claiming or proving they somehow primarily use the car under those special operating conditions. Ours fell under the 10k miles/yr but I did not have trouble with getting the oil change done, (at least on paper).
    Preeeus and Mendel Leisk like this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    SOOOOO.......I guess it IS true.
    And I said "depending on model".
    Some incorrect assumptions are being made here, but it's a fairly common misunderstanding.
  4. Mendel Leisk
    41,463
    Seem like the in-between-the-lines here, is not so much when to change the oil, as getting the dealership to change the oil, during the "free" period. I'm kinda glad we don't have that up here. I DIY change my oil every 6 months or 8000 kms, at my convenience, no big deal.
  5. orenji
    orenji Senior Member
    5,887
    3,488
    Depends on the service manual. Early ones stated 5,000 mile oil changes.
