Is My '05 Toast?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DenToyPri05, Jan 8, 2015.
  1. DenToyPri05
    DenToyPri05 Junior Member
    118
    24
    Denver, Co
    My '05 is completely lifeless in the drive. I have been assuming it's the 12v, at least to start.
    So this is what I've pieced together.
    My key fob battery was dying, my car wouldn't start. Had to use the physical key to get into the car. I assumed the 12v battery was dead (but maybe it wasn't); the Parking button had the faint green lights. AAA jumped the car and I limped home, trying to charge the battery with about 30 minutes of city driving, with dash lit up with red BRAKE and triangle lights as well as amber !, VSC, and something else on. The check engine amber light was NOT on until I powered off the car, at which time, only the check engine light was on and a rhythmic buzzing. The buzzing only went away when I closed the window and then the car went quiet and dark.
    I only just now (48 hours later) realized to check the fob before changing battery, which, sure enough, didn't emit the red light when I pressed the buttons. After I did the battery change, the red light comes on when pressing buttons, but no response from car.
    I will definitely change the 12v battery, and hope hope hope this is the fix.
    Did I kill my car by possibly jumping a valid 12v? Ugh...wish I could download all the Prius Gen II data into my head right now.
    #1 DenToyPri05, Jan 8, 2015
  2. JC91006
    16,933
    8,643
    Wow that was hard to read. So much information that really didn't amount to much information.
    Just change the 12v battery and your problems would go away. Assuming none of these problems existed until 48 hours ago.
    PriusGuy32 likes this.
  3. DenToyPri05
    118
    24
    Denver, Co
    okay okay...just trying to include details that may be familiar to someone else. none of these issues existed until 48 hours ago. will change the 12v this weekend. fob battery has been changed and is ready to go. i'll post the results.
  4. JC91006
    16,933
    8,643
    I don't think your Fob battery was the issue, but changing it out won't hurt.
  5. Patrick Wong
    18,210
    6,517
    Your car could be driven after it was jumped. Therefore there was nothing wrong with the jumpstart process and that caused no harm to your car.
    The warning lights that were on probably are indicative of low voltage on the 12V bus. This might be because the 12V battery was so far gone (with a shorted cell or two) that it was putting a heavy load on the bus, depressing the voltage.
    For your future reference, if the 12V battery could be successfully charged (which probably is not the case with your battery), 30 minutes is insufficient time. 8 hours or more would be more like it.
    To effect a charge, the car does not have to be driven - it could just be sitting in your driveway, left READY. Obviously you need to make sure the fuel tank contains sufficient fuel so that the gasoline engine can run from time to time while the Prius is sitting there, motionless.
    In any event, it would be best to replace the 12V battery now, especially if it is more than four years old. The new battery should be fully-charged prior to installation. Many owners have reported their newly purchased batteries were received in a partially discharged state, Optima seems to be plagued by this issue in particular.
    If the fob did not produce the red light when a button was pressed, then it was past-due to replace the fob battery.
    #5 Patrick Wong, Jan 9, 2015
  6. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Your battery was most likely marginally dead and the cold weather sealed the deal. 60miles south of you we have been hovering around -10C tonight and that is good enough to freeze a battery making it even worse. Replace the battery, move on with life.
  7. bisco
    52,779
    2k1, do you chime in on all the 'toast' threads?:p
    alekska likes this.
  8. GregP507
    GregP507 Senior Member
    3,002
    481
    Dealers will love you for this; keep buying new parts until it works. But seriously, you are in need of a good, trusted mechanic. I wish you luck if you haven't found one.
  9. DenToyPri05
    118
    24
    Denver, Co
    I've got a good inde one; he works on our Honda, and he's patient with my never ending questions. He's got all the pedigrees for working on hybrid cars, but I hadn't had anything this major happen to consult until now. He's great and lets me talk his ear off on all the stuff I've read here, plus he encourages me to learn as much as I can, so that when we do talk about the car, what he's telling me makes sense. (this forum has been priceless! thank you all!)
    He's been talking me through possible issues and giving his $ .02 without seeing the car. It's not that he doesn't want the work, he just knows that I don't mind getting my hands in the guts to see what's going on and trying to diagnose and fix issues myself. When I have bitten off more than I can chew, I go to him, and we go from there. I'm usually on the right track.
    Dealing with the dealer service folks is like dealing with an arrogant academic: no patience, disdain for any question I have, and no time to help me understand.
  10. GregP507
    3,002
    481
    Generally speaking, any mechanic who replaces parts until the car starts working again, doesn't have a clue about what he is doing.
  11. Mendel Leisk
    42,271
    OP. I'd suggest to get a smart charger, something around 3 amps, with status lights for feedback. And a decent digital multimeter, to read the battery's voltage, one measure (albeit not the full story) of it's health.
    And read up on batteries, monitor yours, give it a top-up charge periodically.
    Maybe your current one's toast, hard to tell. But if you get involved in it's maintenance then you'll know.
  12. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    On every forum on the whole world interwebs!
    krmcg and bisco like this.
  13. DenToyPri05
    118
    24
    Denver, Co
    Thank you. I did just pick up a new battery today. 84 month warranty, no core charge, NOT an Optima Yellow Top. (My attempt at ordering an Optima the other night didn't go well. As luck would have it, the transaction never completed.) I hope to have this new one installed after dinner tonight.
    Then I can move on to the 120k service. I'll ask my mechanic about battery tenders and multimeters. Oooo...shiny new gadgets to play with.
  14. bisco
    52,779
    you don't need a battery tender unless your car sits for days at a time, or you only drive a mile or two a day. and even the second premise is questionable.
  15. Mendel Leisk
    42,271
    You also don't need a charger if you never leave headlights or even a map light on, or a door ajar. And none of your friends or family do either.
    Just saying. ;)
  16. JC91006
    16,933
    8,643
    If Bisco doesn't use a tender, nobody really needs one.
  17. DenToyPri05
    118
    24
    Denver, Co
    in retrospect, and current thinking: i don't drive my prius enough. it does sometimes sit for 3-4 days undriven. so, now...need to drive it more AND get a tender.
  18. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It is more of an AND statement, not an OR statement.
    If the car sits for prolonged periods AND you drive short distances, then you need to supplement the battery with an external charger.
    If the car sits for prolonged periods then you need to either supplement the battery with an external charger OR drive longer distances.
    My Prius is the weekend mountain goat. It generally sits for 5 days minimum. Sometimes a few weeks and the SKS remains on. However, when it is driven it is driven for at least 100 miles usually closer to 200. It's last commission was after sitting for about a month, it went on an 1800mile road trip. And it has sat there parked since we got back.
  19. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    I wonder why no one has ever mentioned a battery power pack? I have one with a sealed flooded 12 V battery in it. Would one of these work? I got the pic from a Pep Boys Ad $49.99 My pack isn't this one however. Most have a charger port, plug it into the cigar outlet and keep it charged. When the old 12V battery dies, this should work in a pinch. Either lift the hood and connect to jump, or remove the battery cover in back and clip on the clamps over the battery terminals.
  20. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Yes that will get you going. However by the time the Prius refuses to start, the battery is well beyond dead. It takes the Prius roughly 8 hours to recharge the battery. So that jump starter plus 8 hours of READY mode will be sufficient. However I doubt most people want to leave the Prius ready for 8 hours after a dead battery. So the easy solution is to grid charge the battery overnight and most of those can "jump" if needed as well.
