is my 12V battery effecting my MPG?
Discussion in 'Gen 2 Prius Fuel Economy' started by Peteab, Mar 22, 2011.
  1. Peteab
    Peteab New Member
    UK
    Hi I've had my 2005 Prius for around a week now and I'm averaging 52mpg (UK gallon).
    I followed instructions on this forum for checking the 12V battery and found that it was a volt or so under the recommended. would this have much effect on my mpg? as far as i can tell the battery has never been changed since new.
    any advice is much appreciated!
  2. Britprius
    Britprius Senior Member
    5,194
    1,916
    Herefordshire England
    52mpg is not bad for a new owner but a poor 12v battery will affect mpg, do not buy a new battery from the dealers as the correct fit batteries are readily available from motor shops at much better prices about £45- £50.
  3. Mendel Leisk
    38,735
    As long as you haven't recently attempted charging, the battery voltage for a healthy battery should be around 12.6 volt or higher. If you have charged it, just drive it for a bit, with the headlights on too, before checking voltage. A volt or two low (assume you're checking with a digital volt meter) is significant:
    4 or 5 years is a good run for a battery. If you're on the orig. battery you've been lucky. It will leave you stranded soon: get it changed.
  4. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Are you talking Imperial gal.? The battery should read about 12.6 after sitting over night. Hal
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    You folks in the UK are lucky, I hear that you can get the Optima D51 battery with Japanese terminals there.
  6. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    There are many ways a 12 volt battery may fail. One of those ways really pulls down the fuel mileage. (single dead cell) Other ways to have an old battery fail may not effect MPG.
  7. uart
    uart Senior Member
    4,215
    1,201
    Australia
    What exactly were the voltage readings you got?
