Is my MPG actually bad or not?
Discussion in 'Gen 2 Prius Fuel Economy' started by Prius92, Jul 31, 2025.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    According to the EPA, the 2008 Prius is rated 48 city, 45 highway.
    With about half city, half interstate driving, I'm only averaging 40-44mpg.
    BUT, if I look here at Fuelly:
    2008 Toyota Prius MPG - Actual MPG from 700 2008 Toyota Prius owners
    The top 3 averages are 42, 43 and 44 mpg with the averages of all fill ups at 42.3 mpg.
    I had Toyota check out the HV battery, which I rebuilt 2 years ago, it's not "factory new", but it's far from needing replaced (70-75% capacity of new) which is roughly what a 5 year old Prius would show. Dr. Prius app shows all the modules are fine, the temps are fine, voltage diff, etc all good.
    I've rebuilt the motor, put new injectors in it twice, new throttle body, new air fuel ratio sensor, new spark plugs, pretty much anything that has a bearing on MPG has been replaced. No, I didn't rebuild the motor for MPG, it was using a bit of oil and had 190k on it.
    Measuring things with a scan tool, long term fuel trims after driving 50 miles are only 0.78%, which is damn good. This means the car really isn't using more or less fuel than the factory parameters state as such.Short term fuel trims are good too.
    I've checked other obvious things like wheel resistance with the car off the ground, sticking brakes, everything.
    One thing I DID notice, and I'm not sure if it's because it's summer and I use the A/C, I never seem to get a "green battery" on the MFD battery charge status anymore.
    I'm not sure people claiming 55-70mpg are hypermiling or not, but I really can't do so because my commute has a lot of stop and go traffic, on ramps, etc so there are lots of times I have to use a heavy foot to merge.
    So is the 42.3 on Fuelly the "real world" average?
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,352
    982
    Monument, Colorado USA
    Yep that sounds about right as MANY factors can effect MPGs. Gosh, my V-8 Tundra got 10 mpg towing my camper this past week....it was painful filling up that gas tank!! (Makes me wonder if I really would get 20 mpg in the newer V-6 Turbo Hybrid model)
    For fun, I just looked up the lowest MPGs for any hybrid vehicles:
    2024-Chevy Corvette E-Ray, 19 mpg
    2025 Toyota Sequoia 1794 Hybrid: 20 mpg
    2025 Land Rovers (PHEV): 21 mpg
  3. Prius92
    595
    122
    Iowa
    I've heard the AC and cruise control lower MPG, but I'm not sure to what extent.
  4. Hayslayer
    Hayslayer Active Member
    536
    327
    The AC 100% affects fuel mileage. That compressorCruise control can go either way depending on terrain. A nice long flat highway? No reall differrence between CC and a light foot maintaining speed. Throw in some hills and it's a whole different story. A light foot will always win, since you can let the car pick up speed on downhills and then feather a bit on uphills.
  5. Prius92
    595
    122
    Iowa
    I know the AC affects it, just not sure how much.
    Someone was telling me they put in coils out of a 1.8 in a 2019 corolla and it made a big difference. I don't think they even use the same connector or would even bolt in?
  6. bisco
    52,863
    hvac effect is variable based on outside temp and humidity and cloud cover. and of course, the temp setting of the car and blower speed
  7. pasadena_commut
    pasadena_commut Senior Member
    3,068
    954
    Southern California
    So many variables for MPG. Keep in mind the Federal MPG test doesn't correspond to the way basically anybody drives.
    "City" can mean many things. Once our 2007 is fully warmed up (which takes a surprisingly long time, what with the silly thermos tank) it gets in the high 40's in suburban driving. That is, top speed around 40 mph and distance between stops on the order of 3-5 blocks and making the lights maybe 30-40% of the time. Take it to downtown LA (or most other major cities), with nothing but single block hops and frequent stops to avoid delivery trucks, Ubers, taxis, crazy people (many varieties), jaywalkers, and so forth, it would be more like high 30s.
    "Highway" also means many things. I rarely go over 73 mph even on an empty highway. It doesn't really get me there significantly sooner but the air drag goes way up. The main exception - long downhills, and even then only when there are people passing me at 5 or 10 mph above my speed, who will draw the CHP instead of me. (I'm teflon when there are yellow or red sports cars zooming by.) If all I cared about was highway MPG I would drive at 50 to 55, but that is suicide on most of the highways I frequent, other than in heavy traffic. I have seen 70 MPG on the meter while boxed into the wake of a semi while doing 73 mph on I5, but drafting like that is too dangerous to do routinely.
  8. pasadena_commut
    3,068
    954
    Southern California
    Just for the sake of discussion here are two driving segment displays from today on our 2007. (Actual MPG is less, this display always errs on the "too efficient" side.) This trip was made entirely on suburban streets, top speed was 45 mph, briefly, more common would be 30 mph, with an elevation change of around 400 ft. outbound and a little less inbound (see below). The cabin fan was on but the A/C was not. The temperature shown for outside is close since this was the end of the segments. It is usually way off at the beginning of a drive as the sun heats up the air inlet area and that in turn heats the incoming air substantially. Worst car I have ever had for that effect.
    The full trip was:
    car cold (had not been driven in a week)
    home to bookstore, about 7.5 miles, uphill mostly (outbound image)
    car in P at bookstore for 10 minutes (not shown)
    bookstore to grocery store, about 2 miles, slightly downhill (not shown)
    car off for 20 minutes (not shown)
    grocery store to home, about 5.5 miles, downhill mostly (inbound image)
    In the outbound image it took about 10 minutes to fully warm up, in the inbound image it took less than 5 minutes. The 2 mile segment wasn't recorded because it was only about 7 minutes, or a bar and a half.
    Also the trip mileage of 74 is from when the 12V battery was disconnected to charge it, so the car will have forgotten some of the engine settings, and not have fully determined the new ones yet.
    Yes, the display is very dusty at the moment.
  9. Prius92
    595
    122
    Iowa
    So is it common for the MFD to actually report lower than actual?
    I drove roughly 180 miles 3 times and got gas each time roughly the same outside temp, and each time the calculation of MPG from the old school method of miles and gas used showed it was getting 2.8-3.3 MPG higher than the MFD.
  10. pasadena_commut
    3,068
    954
    Southern California
    Neither the 2007 Prius we have now nor the 2003 Honda Civic Hybrid we had before that ever had a true MPG (delta miles over delta gallons) that was better than the car's estimate. That is, the MPG estimates were always optimistic.
  11. ebikeman
    ebikeman Member
    121
    Northwest
    I have a 3 year old, new dealer installed battery ($6,000), car all tuned up, runs real nice and I get about 32mpg if I hyper mile it. I would love to get 40.
  12. dolj
    dolj Senior Member
    8,648
    4,398
    Wellington, New Zealand
    That is pretty poor. Even 40 MPG is awful.
  13. pasadena_commut
    3,068
    954
    Southern California
    $6K? Did they put two in?
    No healthy Prius should get 32 mpg except under very special circumstances. The most likely would be that it is only ever driven on very short trips, under a mile. Check that the brakes aren't dragging (one or more wheels will be hot), that there are no codes, and that the ICE air filter isn't blocked. Honestly, if mine was doing that and I couldn't figure it out myself it would go in for service. Not, however, to the thieves who installed that battery.
  14. ebikeman
    ebikeman Member
    121
    Northwest
    I'm up to 37 now. The place I was at I had long downhills and put the battery in green three times.
  15. Prius92
    595
    122
    Iowa
    I read the thread on the "Weak EV state" and not sure how true it is, and if so - how to correct it.
    I recently had some service done at the stealership and they checked every little thing on it and nothing is wrong. Fuel trims still good.
    I did notice I can really squeeze out more MPG if I BARELY touch the throttle pedal.
    I wonder after 200k if the pedal position sensor is worn out? Do they ever go bad?
  16. bisco
    52,863
    rarely, not sure if it would throw a code. something tech stream might be able to test, idk.
  17. bisco
    52,863
    what are we really discussing here? you have a 17 year old car that's getting fuelly average, without taking into account any possible adverse circumstances
  18. Prius92
    595
    122
    Iowa
    I did discover my tires were low. When I had a tire replaced the shop reset them all to 32.
    I put 40 in the front and 38 in the rear.
    So far we're up 2mpg.
