Is my traction battery going bad?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jdonalds, Jun 28, 2015.
  1. Patrick Wong
    18,210
    6,517
    I also had difficulty with Windows 7 64 bit OS so I bought and installed Windows 7 32 bit OS and that worked fine. There are several offers on eBay, priced in the <$60 range.
    windows 7 32 bit home | eBay
    #81 Patrick Wong, Jul 9, 2015
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    uart likes this.
  3. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    That's the thread I followed yesterday with no positive results. But thanks for the input and encouragement that it can work. I'll go through it again today to ensure I didn't miss something or make a mistake.
    One problem is some of the steps don't work. For example he said to go to the Device Manager where you'll find two failing devices in yellow to modify. I had no such failing devices. He also mentions using WINRAR which I didn't seem to need as everything was already unpacked in dropbox.
    I am a very tenacious guy when it comes to software issues (spent 40 years working mostly in software). I'll keep banging away at it.
    #83 jdonalds, Jul 9, 2015
  4. jdenenberg
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That's because the newer OS finds a driver to install itself so no errors show up. The installed driver will not work with Techstream, so follow the remaining instructions to install the MiniVCI driver from the CD.
    JeffD
  5. jdonalds
    541
    225
    Thank you. I'll follow that instruction.
  6. jdonalds
    541
    225
    Ah. Now sitting in the car I realize I did yesterday follow the instructions to manually install the alternate drivers. I'll do it again though.
  7. jdonalds
    541
    225
    Okay I had to abandon the 64-bit work. After five hours and many fails it isn't going to work. So I've loaded virtualbox. The only stand alone OS I have is ubuntu. Does TechStream work in ubuntu? Is there a unix based version I can download?
    I have access to XP but not until Saturday. I see TechStream runs in W7/8. Does it run under XP?
    #87 jdonalds, Jul 10, 2015
  8. Patrick Wong
    18,210
    6,517
    Yes
  9. jdonalds
    541
    225
    Great. Thanks. Now I have to wait until Saturday when I should have the XP OS in hand. Not too bad a wait considering the TechStream and cable arrived a week early.
    Another strange behavior in the Prius today. Under normal conditions we rarely see green charge bars, only when going down the 1/2 mile long hill near our house.
    Today we saw full charge, both green bars, several times over a 15 mile trip. The trip consisted of mostly 35-45 mph country roads, and an elevation rise from 750' to 1200'. This just adds to the odd behavior and under 40 mpg recent results. We are now on our third tank of gas with the car showing under 40 mpg. Prior to that, on the 4th tank of gas and previous, we constantly had 45-47 most of the time.
    I'm anxious to get a look at the HV battery with TechStream.
  10. Patrick Wong
    18,210
    6,517
    And there are no warning lights on; and no warning icon in the MFD upper left corner?
  11. jdonalds
    541
    225
    No warning lights, and no codes from the service connector on the Scangauge II
  12. RogerHq
    RogerHq Junior Member
    70
    SWEDEN
    I guess U shouldn't if "grid balancing" is what I believe it is, balancing the HV-cells. That's included in the Hybride system, at least in GenIII. Correct me if I'm wrong ;-)
  13. RogerHq
    70
    SWEDEN
    I just replaced my HV battery pack with a used one the last day. There is still a Triangle lit and the system still says "CHECK HYBRIDE SYSTEM" and refuses to start. Ipad app Enginelink, says the battery is at 40% so the battery ECU is working I guess. It even gives me the states of individual cells and their difference. Alas, it gives me no codes. Does anybody know where I can get a working copy of mini VCI to get out the error codes with Techstream? Enginelink can't do that as far as I know...
    I need fast delivery and a relieable eBay/Amazom/Aliaba-dealer I guess. Living in Sweden, Europe
  14. strawbrad
    953
    1,007
    Did you push the handle DOWN on the orange safety plug? There are three steps to install the orange safety plug.
    1. Insert the plug.
    2. Rotate the handle up.
    3. Push the handle straight down.
    Brad
  15. RogerHq
    70
    SWEDEN
    Thanks Brad but my Orange thing is different because it's a GenIII car, sorry for posting on wrong thread!
    I have been encouraged to continue discussing my problem at Newbie in trouble: &quot;Check hybrid system&quot; | PriusChat
    /Roger
  16. bisco
    52,786
    i never heard that before, what's the orange thingy like on a gen III?
  17. RogerHq
    70
    SWEDEN
    May be it's the same after all Bisco, but om GenIII U push it to the Right instead of Down. :)
    (I guess it's oriented differently?)
  18. bisco
    52,786
  19. jdonalds
    541
    225
    Well after much fooling around trying to get the cable/software to work with Windows 8.1 64-bit I gave up and loaded VirtualBox. I then fetched a 32-bit XP OS from my son, loaded it, and finally was able to connect TechStream to the Prius. However...
    About mid-day yesterday the Prius mpg jumped back up into the 40s. We had two full tanks, about 500 miles which were 35 mpg or under, almost unheard of for our car (only twice in 7 years and we could explain those incidents). Then 1/2 way through the third tank of low readings we noticed the car was behaving normally again; the average mpg is up to 42+ mpg even with the first 1/2 tank being lousy. By the time I had gotten the cable and TechStream to run the car had returned to normal behavior.
    All HV battery readings, in fact all readings, seem to be normal now. Something strange is going on. You can't fix it if it ain't broken. All I can do at this point is monitor the car and connect up the cable and laptop if it starts acting up again.
    What a bunch of nonsense this has been. Of course I'm happy to see the normal HV battery behavior, but now I'm wondering what the heck is going on with this car.
  20. bisco
    52,786
    5 pages, and 100 posts, and we're back to square one?(n)
