Is nav screen cover-only replaceable?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by web1b, Jul 2, 2012.
  1. web1b
    web1b Active Member
    817
    52
    If a screen is stained with a cleaning product that cannot be wiped off because it has soaked through to the back side of the plastic, can just the screen cover be replaced or does the entire nav system need to be replaced?
  2. peterjmc
    917
    188
    Clarksburg, MD
    According to the parts diagrams, the screen does not have it's own part number.
    2010 Toyota PRIUS JPP-REGULAR 10628 86-03 Navigation & Front Monitor Display
    I'm sure it can be purchased separately. It's pretty ridiculous that one might have to purchase a whole new navigation unit just to repair a screen. Maybe try calling Toyota customer service or your local Toyota parts department?
    Just so you know, the screen can be removed from the head unit without taking the head unit out of the car. I took my head unit out to lay down a screen protector over the navigation screen and discovered after the fact that I could have just left the whole unit in and taken just the screen section out.
  3. AmandaL
    AmandaL New Member
    I cracked the plastic cover over my navigation screen, and I am very interested in removing the screen without having to remove the whole navigation unit. Any help you can give would be greatly appreciated!
