Is oil change part of 5k "free" service?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by cyclopathic, Mar 25, 2015.
  1. bisco
    51,892
    don't 'they' say to keep the good tyres in the rear?
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    You just HAD to say that, didn't you ??
    I think the advocates of that are using "junk science" but it's been debated to DEATH in this and many other forums so there is no need to do it yet again.
    Put the new tires where you think they should go and don't worry about it.
    If you don't drive too fast for conditions, it won't be a problem either way.
    51,892
    not arguing, i think i read it on tyre rack with a sensible explanation. but i can't prove mmcc either.:cool:
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Sure if you don't care about steering, braking and accelerating
  5. Easy Rider 2
    1,584
    258
    Ocala, FL
    I absolutely agree with you.
    As well as being able to recover from a loss of rear traction a LOT better than loss of the front.
    BUT.......this "myth" is so firmly entrenched in the tire industry that you and I will never make a dent in it.
  6. cyclopathic
    3,292
    547
    2014 Prius c
    Well it has probably been around since when all cars were rear wheel drive. On FWD with 2/3 weight riding on front? No
  7. Mendel Leisk
    41,397
    Swapping to snow tires, there's no reason not to rotate. I do notice the fronts are invariably less tread than the rear, whenever I'm pulling them off. A 32th at most. But that's in a single, low mileage season.
    If you're using a single set of tires through 4 seasons, I think you could skip the 5000 mile tire rotations, just rotate them every 10000 miles, and it would work out about the same.
    You'd still need to go in at 5000 mile interval though: they've gotta check the drivers floor mat you know. :LOL:
  8. bisco
    51,892
    the only way to debunk a myth is with facts.
  9. cyclopathic
    3,292
    547
    2014 Prius c
    Give me the facts which support rear tire notion
  10. bisco
    51,892
    exactly.
