Is Prius Extra Flood-worthy?
Discussion in 'Gen 3 Prius Technical Discussion' started by namor, Aug 22, 2011.
  1. namor
    namor New Member
    I was driving our 2010 Prius last night in a torrential thunderstorm. Despite being on a divided highway (not a backroad), we came upon a low point in the road that was awash but in the dark could not tell how deep. To make a long story short - we drove into it and found it about doorsill deep, maybe deeper, deep enough to create a bow wake. But the Prius made it through, no warning lights on the dashboard, and drove normally the rest of the way home. I'm sure a regular car of its size would have stalled, with the exhaust almost certainly covered over in water. My question: does the hydrid engine offer greater protection in this case? Did we go to all electric drive while in the water, so it didn't stop? My only other theory involves divine intervention...
    TIA
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    No. The engine is above the level you described. Flood water can be especially bad for the Prius, given all of the electronics and associated connectors. Flood water getting into the Prius is generally enough to total it, even if it only covers the floor pan.
    Tom
  3. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Electricity and water and not good companions.
    If the water was up to the door sills, you might want to make an appointment to have a technician look into possible latent water damage in the battery compartment.
    Just might be prudent.
  4. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    if you made a wake, and didn't stop in the puddle, I would think you pretty much threw enough water out of the puddle to not do any damage. I wouldn't be concerned.
    If you came out to a parked car that was sill-deep, then I'd have concerns.
  5. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    I still don't understand why people think covering the exhaust will kill the engine. As long as there is some volume in the exhaust close to the engine with gas in it rather than water the engine will be fine. If the engine is running this will be the case most of the time. It's the -intake- that can't take water. ;)
    Most stalls in water involve either the intake or the ignition. The Prius intake is up about 18-24" above the road and the ignition is on top of the engine.
    The traction battery is the most vulnerable part. It's about 18" above the road but as long as you don't stop in the deep water you can run through even deeper water than that without it getting that high in the car. The problem is the intake will flood and WILL stop you, with the consequence of the water then getting into the battery via the spare tire drain hole and probably other gaps. The cabling is protected. If you drive in rain (which we all do) it gets soaked. That never causes problems. Hence I wouldn't worry about it.
    Check under the spare tire for "sandbars" or mud, which would be evidence of water coming in. The water should be gone by now, and probably didn't cause any damage.
  6. namor
    namor New Member
    Excellent point David. My concern regarding the exhaust was that once covered, it sets up significant backpressure to the cylinders, which eventually kills the engine (think of Eddie Murphy in "Beverly Hills Cop", plugging up the squad car with bananas in their tailpipe). I will inspect to see if water got into the spare area too.
  7. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Within reason, underwater exhaust isn't a problem. That's fortunate or a lot of boats engines would be SOL
    1 foot of water above the exhaust outlet results in 0.43 psi of back pressure, it would make your car sound like a quiet motorboat but do no harm.
  8. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    The exhaust is not a problem. Lets compare it with same discovery SUVs with the air intake routed up to cabin level, but no special routing for the exhaust.
  9. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Are you sure? I thought you might be ok with a diesel but wouldn't you require the exhaust above the water on a petrol?
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I'd go with your only other theory. I'd work hard to avoid flood waters with a Prius...and even most other vehicles.
  11. David Beale
    5,963
    1,983
    Edmonton Alberta
    If the engine stops and you're in water deep enough to get into the exhaust and up to the valves, then you could be in trouble because stopped, the engine can leak gas through the combustion chamber to the intake. But by then the intake would also be under water as would the hybrid battery. The car would be toast.
    Because the exhaust goes -down- with no holes to atmosphere, if the engine is running it keeps gas (exhaust gas) in the exhaust pipe and manifold and water out. Both diesel and gas engines do this.
    Finally, if you -suspect- the engine might have ingested water DO NOT let it try to start!! It will hydraulic lock, bend a connecting rod and destroy itself! Water, oil, or gasoline do not compress much (for most purposes not at all). If trapped in the combustion chamber it will stop the piston from rising all the way and something else will have to give - usually the connecting rod. Remove the spark plugs. Clean and dry all electronics, including the hybrid battery. Let the engine crank over a bit to force the water out. Make sure the intake is dry. Then and only then, replace the spark plugs and try to let it start the engine. But before that you may also want to change the engine oil in case there is water in there and also change the HSD oil.
    Some advice for those unlucky with Irene.
  12. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Not to bring back a dead post.. but this guy in his Gen.III drove through some DEEP water. And he seemed to be making it.
    Lightning Racer, danlatu, RMB and 2 others like this.
  13. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    If I understand the physics of it, as long as he can keep moving and keep pressure on the exhaust the car will move, now as to water getting into the vehicle and shorting battery . . that is another issue. either way he is a dumbazz for trying this stunt because he will get into a jam and rescuers will have to go after him risking their lives.
  14. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    I'm in no way saying it's a good idea to do it, just showing what Prius is capable of going through in extreme conditions. If it came down to it. One of those things where it's like "I wouldn't do that in my car, but I'm impressed!"
  15. ChapmanF
    15,999
    If a Prius has been into any significant depth of water, the rules for checking it out afterward are in T-SB-0229-12 (you can find it quickly from the techinfo.toyota.com search screen by putting flood in for Keyword: and leaving all the other search fields as ALL, then looking under the TT/SB tab).
    Section 1 is just about steps to make sure the car is safe to work around, and section 2 gives different lists of things to inspect based on how high the water got (level 1, lower edge of rim; level 2, axle centerline; level 3, top of rocker panel/lower door edge; level 4, lower edge of dash panel; level 5, top edge of dash panel) and whether the car was driven in the water.
    Section 3 is then about repairs.
    -Chap
  16. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    Yep I had mine totalled by Sandy. Actually the main battery is totally isolated from the body and the rest when it is in park mode (not sure about driving. The battery is relatively high up.
    The main danger for the engine is water going through the airfilter (not compressable). Most of the electrical connection is spalsh proof (full immersion on the other hand is NOT safe).
    I recall the manual saying that water up to the center of the wheel is OK
  17. bisco
    49,797
    are we in some kind of time warp?
  18. qdllc
    qdllc Senior Member
    1,370
    399
    Not an expert, but I think any high-voltage points are high in the engine, and your power pack is inside the car. Water would have to come pretty high up to cause a problem...you've likely "sunk" your Prius before it's that bad.
    Any car, if water hits the engine block, it tends to "ground out" the electrical system and weaken the spark in the motor, but some are affected more so than others.
