Is Prius suitable for Pakistan?
Discussion in 'Gen 2 Prius Main Forum' started by Hamza Khalid, Jan 25, 2013.
  1. Hamza Khalid
    Hamza Khalid New Member
    Hi there,
    I am a very big fan of the prius family and am planning to buy it. Here in Pakistan, Prius 2 gen is for sale reconditioned and imported from Japan. It costs less than the local cars such Honda Civic, Toyota Corolla etc but i have a few questions i have been unable to find answers to.
    1. Is it advisable to buy a reconditioned prius? Buying brand new 2012 edition defeats my purpose as it is more expensive than most of the cars in the market.
    2. In Pakistan due to rain there is gathering of hood level water on some roads, is prius impervious to water in that case? My current car, Honda City goes through it no problem, will prius do so too?
    3. The roads quality in Pakistan are very poor and there several very rough roads, will it affect prius drive or anything? Its ground clearance is lower than all local cars so there are chances of scraping on the ground.
    Eagerly awaiting reply.
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    1. Reconditioned can mean many things. More information is required.
    2. Hood level water (I'm thinking about water up to the hood) will drown it. Electric motors don't do well in water.
    3. It will drive as rough as the roads. Ground clearance is low. Roads with deep tracks will scrape. Approximately 16CM I believe or 5.5".
  3. Sajjad Siddique
    Sajjad Siddique Junior Member
    24
    Islamabad, Pakistan
    As far I understand him, he wanted to say it as used car rather than reconditioned....
  4. SteveLee
    645
    180
    North Carolina
    I
    Ok. I believe you said you have already purchased a Prius, the 07. So you have some knowledge about its practical use in your homeland and about buying a used Prius. The usual concerns with used cars in addition to the hybrid parts. But it sounds like flooding may be a serious issue being this car has low clearance, though probably not much more than many other cars. Still, higher clearance sounds more practical.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The low ground clearance would be a concern for me, I believe it's lower than a Corolla. A good driver could compensate for most of that though.
    My biggest concern though would be service and repair. Even in the US, if you have a problem that involves the hybrid part of the car and don't have a knowledgeable Toyota dealer or one of the relatively few competent independent shops nearby, it can be a problem.
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Prius is a robust car for USA-style driving. But sounds like you have a real challenge. Normal road water is not a problem, if you are saying up to 1-meter deep water, that seems difficult. You want to keep water out of interior, so as a minimum you would have to inspect rear compartment and floors after a bad day in the water. Dust and fibers can plug the Hybrid battery fan, so if you are mechanically inclined you could keep an eye on battery and fans etc. Another great feature many use in emergency is you can purchase a power inverter to generate electricity for power outages. In USA, Prius retains resale value very well, so I believe we would be expect used-Prius to cost more than a used-Corolla of similar miles. So if the cost on the Prius is lower, that might be saying something.
  7. PriusCamper
    PriusCamper Senior Member
    13,467
    5,436
    Pacific Northwest, USA
    We had a Pakistani on here last Summer who bought a Prius and right after he bought it the inverter coolant pump died on him. But thanks to PriusChat and his own mechanical skills he was able to diagnose and order the part and make the repairs without much problem.
    So if you're comfortable learning about and fixing your car, you're in good hands owning a Prius in Pakistan. But if you know nothing about cars and don't work on them and have to depend on someone else, you'll be way better off buying the most common type of car sold in Pakistan. Perhaps the lower price for a Prius compared to a basic Honda in Pakistan is because of this reason?
    As for water, nothing but a big truck specifically designed for deep water is safe to drive through hood level water. In general, Prius is going to be safe to drive through water briefly, but like all cars water deeper than 1/2 the height of the wheels is very dangerous. And of course deeper can be done if its only very briefly, but no guarantee...
    The main difference with Prius is how it handles in snow and ice... The car will favor the protecting of the hybrid drivetrain by killing the electric motor when the wheel's spin, which makes it really challenging to drive in icy conditions.
    PS: How much does a liter of Gasoline cost in Pakistan these days?
  8. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I would not try to go through anything more than a puddle in a Prius. I live on a rough road, subject to flooding, muddy at times. For that I have a 4WD vehicle. The Prius traction control renders it almost useless for any sort of real mud or loose material. If the traction control turns on, you may get stuck in that puddle unless you have inertia going in. This in addition to the concerns about getting the very much more complex electronics wet, compared to a conventional car.
  9. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Unless you can't have two vehicles, I say get the Prius, and also get an older car with a mechanical diesel engine, a snorkel, relocate the battery to the trunk, and spend some time trying to minimize water intrusion in the cabin and it's effect on your electrical system. I've had no doubts going in standing water that's up to my bumper on my IDI VW diesel, but I wouldn't be nearly as confident in my Prius.
  10. Hamza Khalid
    A litre of petrol here in Pakistan costs Rs103 rupees approximately $1.05.
  11. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Not too bad at all about $3.97/gal
    Hamza Khalid likes this.
  12. priusrat
    priusrat Junior Member
    CT
    Low ground clearance would be an issue. Also, I feel every bump in the road in my prius. I think you'd do better with a higher clearance vehicle
  13. Sajjad Siddique
    24
    Islamabad, Pakistan
    In Islamabad there is no issue of water flooding after heavy rain due to planned drainage system. However, this problem is being faced in cities like Karachi & Lahore. Moreover, local Toyota authorised dealer in Pakistan does not offer repair services yet. Anyways, I am happy with my prius 07, so far....
    PriusCamper likes this.
  14. ETC(SS)
    7,568
    See if there are people in your area that own Priuses and talk with them.
    If there are not many Priuses in your area you may want to wait.
    The Prius is mainly meant to be used on well paved roads which you may have where you live but
    the Prius is also a low car and water on the road can be a large problem especially if there are no mechanics in your area that are trained for this car.
    Large holes can cause damage to the plastic panels beneath the car. If you look at the under-side of the car you will see what I am talking about.
    Getting repair parts locally might be a little more difficult as well.
    Good Luck.
    Welcome to Prius Chat!
  15. Hamza Khalid
    ummm do you have any car besides prius? when did you buy it? For how much? And mileage? I don't want to get local city or corolla because they are over priced and not safe enough. And have you checked with GT Road Toyota dealer? I heard they do offer hybrid services.
  16. Hamza Khalid
  17. Sajjad Siddique
    24
    Islamabad, Pakistan
    No I don't have a 2nd car with me. I bought it couple of months ago for PKR 1.675 million. In winters it gives between 19 to 21km per litre n in tropical season I experienced between 22 to 24. I will check with them. IA. Thanks..
  18. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I was in Pakistan for a couple of months in 1992, when Pajeros ruled (the old Mishubishi Outlander)! Wouldn't want to drive any car through those chaotic circles in Lahore! Islamabad would be fine, as would the paved highways. Backroads to the villages, through hood level water, I'm not so sure about. We get flooded streets here in Texas, and I haven't found the Prius to be any worse at getting through that than other cars, but there aren't too many cars that can do hood level water for any sustained amount of time. On the plus side, the Prius has a huge amount of interior space, relative to its exterior dimensions. Not a very cushy ride, so those backroads could be a bit rough. But probably not any worse than a Honda city car (not sure what that is, so I'll guess something like a Honda fit). Another plus is that the Prius is very low maintenance. Transmission should last forever, no belts (depending on year), no starter motor, fewer other electrical parts to worry about, long life spark plugs, etc.
  19. Hamza Khalid
    I have talked with Toyota dealership here and they said they can provide me with the parts and tune up and stuff so that's not the issue.
  20. Hamza Khalid
    Honda City is indeed like a Honda Fit just with a trunk and higher road clearance. And thanks for the info i just need to get hold of a dealer to get a prius now.
