Is replacing TPMS transmitters worth it? I think NOT
Discussion in 'Prius v Main Forum' started by Georgina Rudkus, Nov 27, 2025.
  1. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    When I used a set of winter tires/rims with TPMS, I used an ATEQ QuickSet tool to learn, save, and re-load the correct summer or winter set of TPMS IDs.
    52,841
    i dislike toyotas (and others) insistence on black interiors. we were fortunate to find white in our '24.
    davecook89t and Prodigyplace like this.
  3. Prodigyplace
    12,712
    11,848
    Central Virginia
    Given the choices, I wanted the tan/brown, but the area distributor seemed to be ordering & allocating mainly black interiors. White interior shows dirt too quickly, especially red clay dirt.
  4. Air_Boss
    4,259
    1,197
    New Yawk
    The dark grey SofTex on the 2012 v Five has been bulletproof to stains.
    Prodigyplace and Mendel Leisk like this.
  5. bisco
    52,841
    we're very clean :D
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    No grandkids?
  7. bisco
    52,841
    oh ya. i got a seat cover for the back, and they can't understand why we don't allow food and drink in the car anymore :cool:
    Prodigyplace likes this.
  8. Prodigyplace
    12,712
    11,848
    Central Virginia
    No grandkids here but do not expect any either. One son married and the older one still single.
  9. gatorback
    gatorback Junior Member
    60
    Inherited a 15 year old Prius last summer and dead TPMS sensors.
    $100 Total: four OEM sensors for $40 from eBay and Discount tire installed /programmed them $60.
    I leave it others to debate whether it is worth spending a single penny (or more) on tire pressure monitoring, however, I think it is cool tech and am OK with $100.
    Air_Boss, bisco and Prodigyplace like this.
  10. bisco
    52,841
    for a hundred, i'd do them all when i needed tyres
  11. 97trophy
    97trophy Junior Member
    Or Walmart, $29 per wheel, fitted & synced.
    bisco and Air_Boss like this.
  12. Dan H
    Dan H Member
    50
    29
    Miami FL
    2015 Prius v wagon
    I feel it is worth it to have a working tpms. Since they all go out eventually I bought the Autel MaxiTPMS TS508WF TPMS Relearn Tool and have replaced 6 on various cars. Replacing the bad sensors is pretty easy and I can do one in about 5 min now. I jack up the entire rear of my car and then I position a large steel pipe with a cap under my hitch receiver and drop the weight down on the tire(deflated) to break the bead near the bad sensor. That way the sensor can easily be removed and replaced. Just make sure everything is clean and I have had no problem doing it this way. Reprogramming is easy using the Autel tool and aftermarket sensors.
    Air_Boss likes this.
  13. rjparker
    rjparker Tu Humilde Sirviente
    11,086
    6,948
    Texas Hill Country
    It is so easy and low cost that I can't understand the guys who refuse to repair a safety device that prevents blowouts on 20 psi tires but are willing to spend days and or $900 making egrs spotless.
    BiomedO1 and Air_Boss like this.
  14. gatorback
    60
    I'd like to look at said Autel tool. Do you have an Amazon link or the like? Thanks!
  15. Prodigyplace
    12,712
    11,848
    Central Virginia
    Google is your friend. ;)
    hxxps://
  16. BiomedO1
    BiomedO1 Senior Member
    4,589
    2,409
    Left Coast
    It's probably the same reason some people refuse to wear seat-belts... ADHD???? Perhaps we can ask our current health czar's brain worm?
    Hey; that's why we have Darwin........
    #36 BiomedO1, Jan 25, 2026
  17. Winston Smith
    Winston Smith Active Member
    473
    339
    OH
    2024 Prius
    LE AWD-e
    Or people maintain their cars and know what a low tire feels like, and don't like the extra expense.
    Some systems don't require a sensor inside the tire, and they seem to work well enough. Part of Toyota's charm is that it is technologically conservative and reliable. Maybe they'll switch in the future.
  18. rjparker
    11,086
    6,948
    Texas Hill Country
    Honda's system uses the abs sensors to detect different rotational speed of a low pressure tire. But all tires low is missed and there is no warning on startup.
  19. Winston Smith
    473
    339
    OH
    2024 Prius
    LE AWD-e
    Indeed. It works nicely.
    You don't need a low tire pressure sensor on start up, and if one can't tell that he is driving on four tires inflated to 20 pounds and could discern that by looking at the tires, he should buy a car with sensors in the tire.
    Not everyone can, or knows what to do if a tire is low. One of my children drove home on a flat tire not understanding that it would be chewed up in the process.
  20. BiomedO1
    4,589
    2,409
    Left Coast
    Hopefully you made that child pay for that. Lessons tend to stick, when it hit's them in their pocket-book.
    Otherwise it's like when parents talk to Charlie Brown, in those cartoons....o_O:notworthy::sleep:
