Is Someone Sawing Down a Tree Under My '09?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jimolson, Jun 1, 2016.
  1. jimolson
    jimolson Member
    161
    63
    Indianapolis, USA
    Yes, this is another posting about peculiar under-hood noises. Sorry.
    I think my 2009 Prius has occasionally made what I call "the sawing sound" since I purchased it new. (It now has 134k miles on it.)
    For you young pups who think all saws have round spinning blades, I hail from a bygone era where trees were felled by hand using a two-man crosscut saw.
    My Prius now emits this hand sawing sound continuously. It's no longer an intermittent thing.
    Is this sound the that posters often refer to as the Barking Seal Noise? If not, what is it? Does the fact that the sound is now continuous while the vehicle is running mean that brake failure is pending?
    I just received my first notice from Toyota about warranty extension for brake pump problems. Does this warranty extension pertain to my sawing noise?
    Jim in Indianapolis
  2. JC91006
    16,933
    8,643
    do you have a check engine light on? Maybe it's the sound when the 3 way valve fails.
  3. jimolson
    jimolson Member
    161
    63
    Indianapolis, USA
    nope, no CEL. Just the noise.
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I'm guessing 3-way valve, too. Mine made noise for a few years before throwing the code. The valve lives under the inverter in front of the left front fender. You can use a length of heater hose as a cheap stethoscope.
