Is something supposed to be bolted here?
Discussion in 'Gen 3 Prius Main Forum' started by vendingtech, Sep 2, 2018.
  1. vendingtech
    vendingtech Member
    83
    51
    Snowflake Az
    Please see photo of inverter in my 2012.
    Is something supposed to be screwed to those holes near the bottom front?
  2. prev93
    prev93 Member
    63
    Califon, NJ
    Yes, there is a bracket there that connects to the front of the car. Not sure how vital it is, but my 2010 has it.
  3. Mendel Leisk
    42,293
  4. BZzap!
    BZzap! Senior Member
    1,607
    878
    Has your car ever been to the body shop for front end repair? Looks like the ol, “It don’t need it” repair.
  5. ETC(SS)
    7,514
    Asked and answered.
    Either a sloppy mechanic didn't replace it following an inverterectomy, or the car got socked in the nose in a previous life, and was repaired by some third-rate 'Beat-n-Bang Body Shop'.
    padroo likes this.
  6. vendingtech
    vendingtech Member
    83
    51
    Snowflake Az
    Anyone have a part number on that? I'd like to try to eBay it. Thanks
  7. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    #7 m.wynn, Sep 5, 2018
    Mendel Leisk and Raytheeagle like this.
  8. Mendel Leisk
    42,293
  9. Mendel Leisk
    42,293
    I compared the bolt on the black plastic piece, with a bolt on the hold-down bracket:
    They're both 10 mm socket size (6mm dia at the threads), and the same thread pitch. Both taper down for about 1/8" at the tip. The hold down bracket is longer, about 36 mm from underside of bolt head to tip, and has a captured flat washer.
    (Hold-down bracket bolt on right)
    Found this in Repair Manual:
    #9 Mendel Leisk, Sep 5, 2018
    m.wynn likes this.
  10. Mendel Leisk
    42,293
    Again, what is the history; was there a collision repair? Maybe some body shop couldn't get the bracket to fit due to misalignment, so just quietly ditched it?
  11. vendingtech
    vendingtech Member
    83
    51
    Snowflake Az
    I don't know that history. Clean car fax but who knows. I'll be looking for the part just because. Thanks for the bolt pics! That guarantees I get the perfect length bolts!
    Thanks everyone for your assistance.
  12. Mendel Leisk
    42,293
    Wherever you're getting your bolts, bring along that one from the plastic piece: while it's shorter, it's the same diameter and thread pitch, so if you can find a metric nut that fits it, then check the nut fit on the bolt you're going to purchase. A dealership parts department would be the place to get the kosher bolt, correct part number, dimensions, grade. It'll also be pricey, but the safest route.
  13. vendingtech
    vendingtech Member
    83
    51
    Snowflake Az
    https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F231934528506
    eBay is your friend. Popped in that part number and there it was. Thanks for the help!
  14. vendingtech
    vendingtech Member
    83
    51
    Snowflake Az
    Mendel Leisk, m.wynn and Raytheeagle like this.
