Is "Super Highway Mode" a myth?
Discussion in 'Gen 2 Prius Fuel Economy' started by Briankbl, Jul 29, 2013.
  1. Briankbl
    Briankbl Junior Member
    Okay, I can get killer gas mileage at anything under 55mph. But on my daily commute, I have a good stretch of road that is 65. When trying to use SHM, my car decelerates too fast for this to be a feasible method of driving. In a lot of the instructions I've read, they state to let off of the gas pedal a certain amount and you can usually get between 60mpg and 70mpg. For me, in order to reach that, my car loses 1mph every 5-10 seconds or so. Before I know it, I'm accelerating back up to 65 from 50 lol. Any advice on SHM would be great, thanks!
    Droid DNA ? 2!
  2. fuzzy1
    10,676
    My memory of Wayne Gerdes' description (at CleanMPG.com) is that SHM really ought to be practiced with an engine monitor (e.g. ScanGauge-II or similar device) to get the correct IGN and TPS values. And it is very unlikely to work at 65 mph.
  3. Sabby
    Sabby Active Member
    295
    127
    SoCal
    I have a Scanguage and use it at ignition at 22 to get SHM when going down hill or on a flat road. On the HSI it corresponds to just over the centerline. Pick that point and let there be a slow deceleration. MPG will pop up to the 75 plus area. Hope that helps.
    It does work best below 60 mph
  4. Briankbl
    Oh, duh...there's my problem lol. 65 being the speed limit, I would feel like a jerk if I drove below 60 lol. If I'm going 65+, should I just go ahead and use cruise control?
    Droid DNA ? 2!
    PLSPUSH likes this.
  5. Briankbl
    Scanguage II is $160 on Amazon right now :-( Really want one, but I'd rather just use that money on gas lol. One day...
    Droid DNA ? 2!
  6. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    CleanMPG.com, Wayne Gerdes' website, has a ScanGauge group buy thread where you can get it for a bit less. If you are serious about stretching fuel economy the ScanGauge's xgauge gives you access to some settings other, cheaper gauges won't. If you use a smartphone there are apps that use USB-OBDII cables to act as a gauge and there may be apps that are programmable.
    You m8ght be interested in Hobbit's article suggesting that you're bettermoff with high-speed pulse and glide
    Sweet spot refinement
    (Disclosure: I am a mod at CleanMPG)
    Netherland plug-in likes this.
  7. fuzzy1
    10,676
    Those are specific to GenIII. OP has a GenII, no HSI gauge, and should aim for a different IGN value.
    Or support the PriusChat shop, $159.95. Or support CleanMPG.com, $134.95. Or wait for the occasional Amazon deal of the day, something around $125.
    Or get the baby ScanGauge (just 2 display items, not the regular 4) for around $100.
    Or since you already have a smartphone, try one of the apps (Torq?) that just needs a Bluetooth OBDII dongle.
    Silver Pine Mica likes this.
  8. vskid3
    vskid3 Active Member
    773
    228
    I would like to add the Ultragauge to that list. Its $70 and does a great job (but can't read any of the Prius specific sensors). Would be better than the baby Scangauge (called the Scangauge-E), which costs more, only displays 2 gauges at a time, and still can't do xgauges.
    Torque on an Android phone/tablet is the most useful per dollar for a Prius. A cheap bluetooth scanner ($15) and the app ($5) are all you need if you already have an Android device. With the customs PIDs, you can see just about everything the car itself sees.
  9. theshark
    theshark Member
    164
    Martinsburg, WV
    SHM!?!
    Is this some sort of modification? I don't have a SHM option anywhere in my 07 Prius?
  10. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    Yeah, you just have to adjust the nut behind the wheel. ;-)
    LG-AS695 ? 2
    fuzzy1 and PriusGuy32 like this.
  11. theshark
    theshark Member
    164
    Martinsburg, WV
    Hardy Har Har!!
  12. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
