Is the C engine beltless like my liftback G3?
Discussion in 'Prius c Main Forum' started by Troy Heagy, May 30, 2014.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    A/C, oil pump, coolant pump..... all driven by electricity rather than a belt (tied to the engine)?
    Does the Prius C's engine have any vestigial pulleys where the belts used to connect (on the older G1 and G2 Priuses)?
  2. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    So easy to pop the hood... ;)
    SCH-I535
  3. NR427
    NR427 Member
    142
    100
    Utah
    The c is beltless.
    Merkey likes this.
  4. Troy Heagy
    Troy Heagy Member
    1,218
    On a car I don't own? ;) (Besides when I popped the hood at the dealer, I couldn't really see much.)
    Merkey likes this.
  5. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    It's beltless, which is hopefully one less thing I'll have to worry about replacing on this car.
  6. Troy Heagy
    Troy Heagy Member
    1,218
    Yeah I've come to despise timing belt service. $1000 down the drain.
  7. Mike500
    Mike500 Senior Member
    2,593
    764
    The Prius"c" engine has a timing chain, not a timing belt.
  8. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    no belts which is a great thing
  9. El Dobro
    El Dobro A Member
    6,979
    3,214
    The Prius engine oil pump runs off the crankshaft.
  10. Troy Heagy
    Troy Heagy Member
    1,218
    Ahhh engine drag (some).
  11. Troy Heagy
    Troy Heagy Member
    1,218
    So to clarify:
    The air conditioner is electric powered, just like the full-sized Prius.
  12. NR427
    NR427 Member
    142
    100
    Utah
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
