Is the extended maintenance worth it?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mrshoeshine, Dec 8, 2014.
  1. mrshoeshine
    mrshoeshine New Member
    2015 Prius Plug-in
    Hey guys, I recently bought a new 2015 PiP and I'm trying to figure out if it's worth paying $1500 for the extended maintenance plan. How much does a typical tire rotation or oil change cost? I found other posts saying that anything above $100 is a rip off. They said it was like ~$50 per the oil and the filter but that was for older non-PiP models. The person at the dealership said an oil change for the new PiP can cost about $300 since the filter is special and it uses synthetic oil. I feel like I'm getting ripped off after reading most of the posts here but none of them were talking about the new PiP. I'll call another dealership tomorrow and get a quote but I'm afraid that they're going to lie to me.
    I also bought the extended service plan because I was told that I can cancel it within 1 month and get a complete refund. It seems like the service plan is probably not worth it, especially since it's $2000.
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    No I feel these plans are a high profit dealer add on and are not worth it.
    The "special" oil change and tire rotation cost $89 at my dealership for a 2015 Prius plugin.
  3. GregP507
    GregP507 Senior Member
    3,002
    481
    These plans are calculated to make money based on statistics. Occasionally, they come in handy, but in the majority of cases, they are just overpriced insurance.
    When I lived in Montana, there was an exposee done about how people were being duped on extended warranties on used cars. Sometimes, the "warranty" doubled the cost of the car, and the terms weren't clearly spelled out. The dealers were apparently making stuff up, based on how gullible they thought the customers were.
    I know of one case (for an electronic item) where someone bought the store warranty on a PDA, ( a $300 Palm Zire) thinking it would provide extra coverage. Shortly after he bought it, it slipped out of his hand, and he dropped it about 3 inches onto a table, and it stopped working. He brought it back to the store (a large office-supply chain) and he was told that the manufacturer's warranty would have covered it, but it was obviated when he bought the store warranty, which excluded breakage due to dropping. He found out that he had paid extra for reduced warranty coverage.
  4. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    Your friend with the PDA was misled. The manufacturer's warranty is never nullified by the purchase of an additional one. I suspect he bought a "grey-market" PDA without a U.S. warranty in the first place.
  5. bisco
    52,890
    not worth it.
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
  7. Mendel Leisk
    42,369
    The OP's plan is extended maintenance, not warranty.
    Anyway, both are a waste.
    retired4999 likes this.
  8. GregP507
    3,002
    481
    I'm not sure I understand the distinction.
  9. Mendel Leisk
    42,369
    Isn't extended maintenance just pre-payed maintenance plan, doesn't cover component failure? I'm not that sure myself.
  10. GregP507
    3,002
    481
    He may have been misled, but that's what he was told as the reason Staples wouldn't do anything for him.
  11. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    It's either an extended warranty or a prepaid maintenance plan. The original post can be a bit confusing but I believe the question is about the prepaid maintenance.
    The new car already has 2 years/25000 miles of prepaid maintenance. The addition plan, if it starts from day 1, is an overlap. My bigger concern is that the dealer is feeding you pure BS. The PiP uses the same oil & filter as every other hatchback. Pay for the maintenance as you go, it's cheaper that way. If your dealer really charges $300 per oil change then after the Toyota Care expires you need to find another shop or DIY.
    ftl likes this.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    PiP filter and oil is the same as a regular Prius.
    Dealers charge ~ $45 for oil+filter change using Toyota recommended, excellent products.
    Cancel both plans
  13. mrshoeshine
    2015 Prius Plug-in
    Thanks for the info everyone, I'm going to call in and cancel both later today.
    You guys are awesome. :)
  14. CharlesH
    2,798
    1,166
    Roseville, CA
    The pre-paid maintenance plan covers only scheduled maintenance. It is real easy to see what the tradeoff is: find out what the dealer would charge for all of the scheduled service past 25K up to the limit in the maintenance plan, and compare that to what they are charging for the pre-paid maintenance. This is assuming that you plan to use the dealer for the maintenance, and not DIY or done at a non-dealer shop.
    The extended warranty covers things that break outside of the factory warranty. It is commonly known to be extremely over-priced insurance making big $$$ for the dealer.
  15. mrshoeshine
    2015 Prius Plug-in
    When I was talking to the person at the dealership, it definitely made sense at the time because he was saying the cost of tire rotations and oil changes were really expensive because the PiP had a special filter, synthetic oil, etc, etc.
  16. Mendel Leisk
    42,369
    I'm getting, thru dealership parts dept:
    Toyota 0W20 liters: $5.65 (Can)
    Filter element: $8.53
    Drain bolt washer: $0.98
    The PIP is same items I think.
  17. Epiphany2000
    Epiphany2000 Member
    126
    San Francisco Bay Area, CA
    At best, you'll just give money to the dealership now that you would otherwise spend later. At worst, you'll have an irresponsible, overpriced, and incompetent shop serving your car (not all dealerships are created equal, nor do the have the same service rates). I'll bet you'd do just as well if not much better by taking advantage of the oil change specials that the dealerships offer from time to time, rather than prepaying now for maintenance service now.
    Come to think of it, does a maintenance package require you to get the service done at the particular dealership that you buy it from? I would assume not, but I'm not sure.
    To sum it up, the answer is no. Keep the extra cash and retain and ability to take your car wherever you want for service in the future.
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    And skip the 'minor' services.
    Personally, I swap tyres around and change the oil/filters in my driveway. Once a year, about $20.
  19. Okinawa
    Okinawa Senior Member
    1,333
    320
    Salesmen always have a way of making things make sense when they don't.
  20. CharlesH
    2,798
    1,166
    Roseville, CA
    The maintenance package is from Toyota, and can be used at any Toyota dealership. The service records are kept centrally, so no matter which dealership you go to, they can tell what you have had done and thus what needs to be done (from Toyota's perspective, anyway). This central service record is viewable by the owner, if you want to check what it thinks has been done. I bought the maintenance contract, and when I take it in, I tell them to do whatever is covered by the contract, and don't even bring up any of those "extras" that service departments are so fond of. The only correct value for my bill is $0.00
