Is the Gen 3 unreliable?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MikeDee, Dec 24, 2022.
  1. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    For my 2013 Prius with 105K miles, the only things I've replaced were tires, 12v battery, filters, coolant, and oil changes. Yes, very reliable but worried about the the head gasket and other expensive stuff like being reported in this thread from here on forward.
    iPhone ? Pro
    ukulelegeek and bisco like this.
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    1.3 million miles? Wow!
  3. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    All of my Pri have right at 300K only the 13 persona had a failure . Gen2 nada 3 of them. 10 gen3 that's never off the road except maybe 7 hrs a night been on road since bought used at 160 ish all original. This car got a JY HV battery the day I bought it . And has been rolling ever since . One the lowest maint vehicles in world. Till it isn't . Like many . But costs can drastically be lowered if YOU are Can Do type.
    lovenycpizza likes this.
    52,863
    I’m also concerned about mine, engine was stuttering badly yesterday
  5. MikeDee
    1,581
    597
    Bad/stale gas? I had a problem with short boughts of shaking a couple of years ago. A couple of bottles of Techron cured the problem. I wasn't religious about using top tier gas. Maybe an injector was clogged.
  6. bisco
    52,863
    fresh gas, mobil. i could try some techron to see if it helps, thanks!
  7. Mendel Leisk
    42,355
    Clean the throttle body? While in there you could check the EGR pipe (just the stainless steel pipe betwixt EGR valve and intake manifold, though with your miles and EV usage should not have significant carbon build-up.
  8. MikeDee
    1,581
    597
    What does cleaning the throttle body do exactly? Isn't it just carbon removal from the throttle plates, which doesn’t cause a problem anyway?
    There's also that TSB described in another thread about replacing the intake manifold with a new version.
  9. ChapmanF
    19,035
    Cleaning the throttle body is occasionally needed to get a Prius to restart after the 12 volt battery power has been out.
    The ECM learns how far the throttle must be open for idling and starting. As the throttle gets gradually carboned up, which happens slowly over long times, the ECM keeps up and learns the needed throttle openings.
    If 12 V power goes out, the ECM forgets that learned value and goes back to factory defaults for the next attempt to start. Sometimes that just means a hard start and a lousy idle for a few moments until the right throttle positioning is relearned. Other times, if the carbon is worse, the car will fail to start at all.
    All gens, not just Gen 3.
  10. MikeDee
    1,581
    597
    How does one do the throttle body cleaning?
  11. ChapmanF
    19,035
    Spray carb cleaner on a rag and wipe the edges of the throttle plate and wipe out the bore it sits in until clean. Almost faster to do than to type.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    EGR cooler & replacement is admittedly a pain, especially the first time. After you do a couple, you just roll your eyes and say, "Here we go again with the bruised hands."
    Gen 3 spark plugs are a piece of cake. If you have an impact driver, you can get the wipers, wiper motor, and cowl off in about 10 minutes or less. (Two nuts for the wiper arms, pull the plastic cover off, unplug the wiper motor and get the cable out of the way, remove 3 screws for the brace and 10 for the metal pan, set it aside, and you're ready to unplug the coils.) I actually prefer it to the Gen 2 because, while you don't need to remove the cowl on the Gen 2 to do the plugs, it's pretty crowded in there.
  13. ChapmanF
    19,035
    Really? I guess I've never done plugs on a Gen 2. I seem to remember needing to on my Gen 1, and on my Gen 3. Maybe it's the odd generations. Anybody know for Gen 5 yet?
  14. Mendel Leisk
    42,355
    Whenever I’ve purposely disconnected the 12 volt (typically to avoid mishaps when taking caliper off rotor), the next few start ups I’ll hear the engine do an unusual rev up, sounds like it’s calibrating.
    So maybe, and especially if the throttle body was quite grubby, good to follow up cleaning with a battery disconnect?
    Just pausing the review videos, they look to be accessible without cowl removal, not too far back.
    @NutzAboutBolts video can be found here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    a fair bit of the work is removal of engine air intake plastic pieces.
    I prefer now to also disconnect and lift the throttle body right off, a little easier to thoroughly clean (leave coolant hoses attached). Torque values in attached.
    #34 Mendel Leisk, Dec 26, 2022
    jerrymildred likes this.
  15. cipsaz187
    cipsaz187 Member
    150
    43
    2012 here with the 138k miles on the clock.
    Consumes a lot of oil. Just had to put 1 1/2 of oil because it was barely on the dipstick and only 4500m driven since the last change
    I have an engine knock occasionally on the cold start-up which sounds really bad
    I haven't done anything except replaced the brakes and the wheel hub
    Honestly a lot of things are needed already or coming soon
    I don't have time for major maintenance and not interested throwing money to it. I am already thinking its time to let it go and move forward with something new
  16. jerrymildred
    11,517
    14,170
    Tampa, FL
    There's not a lot of room above the spark plugs on Gen 2, so I have to use just the right length of socket extension and it's easier if I have a u-joint on it.
  17. Tom Toledo
    Tom Toledo New Member
    Colorado
    totally unrelated but I didnt know where else to go to ask this question. how do I post a new topic? I am brand new and at least to me the interface didnt indicate to me an obvious button or link to click to start a new topic. thanks!
  18. Tom Toledo
    Colorado
    never mind. figured it out
    Mendel Leisk and bisco like this.
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    There maybe another thread post about your car on here . Car that haven’t had any oil change services for the last 35,000 miles,
  20. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    Of all the different cars I've owned over the years, my 2011 Prius has been the most reliable vehicle by far. If comparing to recent Toyotas, my 2016 Camry needed more repairs before reaching 75k then the Prius which is currently at 175k.
    Outside of maintenance and normal wear items, the only thing the Prius needed so far was wheel bearings.
    #40 Mdv55, Dec 31, 2022
