Is the generation 3 considered to be a two-speed transmission?
Discussion in 'Gen 3 Prius Technical Discussion' started by Tombukt2, Feb 13, 2024.
  1. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    I was reading the advertisement for a I don't know I think a 2013 CT 200H Lexus and it claimed in the ad that it had a two-speed CVT Is this the same as we have in the Prius? I'm not really a transmission guy I do know we have a CVT. I was just wondering if the CT 200H advertisement was incorrect or maybe this is why it gets seemingly quite a bit less gas mileage?.
  2. ChapmanF
    19,050
    There's definitely nothing about the gen 3 Prius transmission that would justify calling it "two speed". Duná Žno if anything is different about the CT 200H.
    Whole idea of counting "speeds" in a continuously-variable transmission is weird to begin with.
    There have been some two-mode transmission designs over the years.
    Danno5060 and Tombukt2 like this.
  3. Tombukt2
    13,875
    2,521
    Durham NC
    That's what I thought. I have CVTs on my big bore scooters there's no shifting that's continuously variable these two sheaves move in and out and move a belt made out of whatever up and down to change the gearing look similar in a car made the similar way by looking at videos of internals of these transmissions.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    I think the Gen3 has a second planetary gearset, but that's only there to reduce the MG1 speeds (no more 6500RPM limiting everything).
  5. mr_guy_mann
    4,120
    2,018
    NJ-USA
    The Lexus has worse aero design than the Prius, and likely a little more weight. Same reason the Prius V is worse vs regular Gen3.
  6. ChapmanF
    19,050
    The second planetary in Gen 3 is between MG2 and the PSD. It's an MG2 speed reduction gear: it allows MG2 to be smaller and lighter and spin faster, with its speed reduced and torque increased on the way to the PSD.
  7. pasadena_commut
    pasadena_commut Senior Member
    3,071
    956
    Southern California
    Maybe the two speeds refer to the D and B modes?
  8. ChapmanF
    19,050
    If so, it's just somebody being goofy. It's still a CVT, however you wiggle the shifter knob.
  9. fuzzy1
    10,722
    But they are not different speeds.
