Is the Optima Yellow Top a good batt?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jun 17, 2018.
  1. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    In the immortal words of Rodney King, "Can't we all just get along?" :) :) :)
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Sam Spade rules
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    No not really. There are a LOT of conditions which will cause the engine to come on and a low state of charge in the 12 V battery is just one.
    As a matter of fact, I don't actually remember anybody actually saying that a low 12 V , by itself, will trigger the engine to run.
    Since the 12 V charges off the big battery and NOT off the engine directly.......I suspect that the 12 V getting low will just ramp up the DC-DC inverter and won't have any direct impact on the engine running.
  4. sam spade 2
    7,035
    2,804
    2017 Prius c
    Meaning what exactly ?
    You don't like to hear the truth ??
  5. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    Yes, but if the 12v is bad/weak and NEVER FULLY charges, the system continues to use energy out of the HV battery and so needs to run the ICE more (because it is always WASTING energy from the HV battery TRYING to charge the 12v fully, it has to replace that energy). I have not had this experience with my Prius, but I absolutely did experience it with my used 2005 Ford Escape Hybrid (same design as Prius), when I bought it, the battery was weak, but hard to notice since it is not used to start the ICE. I replaced it and immediately got 3-5 MPG better mileage.
    Also, the lower than normal voltage may affect some readings/settings in the car, possibly causing the ICE to run more.
  6. Johnny Cakes
    1,065
    789
    Virginia, USA
    Well put. That's the point I was trying to make. Even with a good, but low-charged battery, it uses energy out of the HV battery until it achieves the proper charge level.
  7. audiodave
    audiodave Active Member
    800
    272
    US
    Even when my 12 volt was weak the charging system still kicked down to 13.6 after driving a bit. Only stayed at 14.2 when the headlights or AC where on. Think that's why that battery didn't last.
    I have a yellow top now and trickle charger it couple times a week to be sure.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    And I think it didn't last because it was worn out or defective.
    A failing battery often LOOKS like it is fully charged and will even "fool" the charger.....but then it can't actually produce enough current do it's job.
  9. audiodave
    800
    272
    US
    Definitely didn't hold a load. Headlights alone dropped it bellow 11 volts.
    j12piprius likes this.
  10. Mendel Leisk
    42,369
    Next birthday, Christmas or whenever, ask for one of these:
    ITBland likes this.
  11. hill
    9,041
    Those got to be the most mismatched size of terminal clamps versus the size of the wire that I have ever seen.
    LG-H918 ?
    StarCaller and Raytheeagle like this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    The BatteryMINDer 1510 is an excellent tool:).
    farmecologist likes this.
  13. Mendel Leisk
    42,369
    I think if everyone got/used a decent battery smart charger, an electronic battery load tester tester, and gave up on trying to figure out how much gas was left when the gauge read empty, this site would fall apart, lol.
    We could get back to cleaning our $(*!@ EGR circuits every month or two.
    ITBland and farmecologist like this.
  14. j12piprius
    j12piprius Junior Member
    35
    Central California Coast
    Is that a good test of battery strength? If so, what should the minimum voltage be with oem headlights?
  15. Mendel Leisk
    42,369
    Akin to checking tread depth with a penny? At least that sort of works.
  16. audiodave
    800
    272
    US
    Mendel Leisk and Raytheeagle like this.
  17. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Ok dumb question....what is the 'proper' way to attach a BatteryMinder in a Prius? I've seen talk of using an under the hood hot point. Is this the'correct' method? Why can't you attach directly to the battery?
  18. audiodave
    800
    272
    US
    Since it's a permanent installation I attached directly to the battery. You can close the hatch with the cord hanging out.
  19. farmecologist
    1,960
    1,801
    Southern MN
    That is what I was thinking. I'm going to install a ring adapter kit at the battery terminals ( which are obviously at the rear of the vehicle ).
    However, nearly every post I see on here when I search seems to imply using the 'boost point' under the hood...which is why I was asking.
    Thanks for your help!
  20. audiodave
    800
    272
    US
    No reason to pop the fuse box and positive terminal to hook up the charger. I just leave the connector plug hanging out the back corner for easy hook up. I don't understand the Prius charging system. I've drove the car a half hour and the charger still charged for like 45 minutes to top the battery off.
