Is the Optima Yellow Top a good batt?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jun 17, 2018.
  1. Mendel Leisk
    42,373
    I connected a CTEK quick connect (a connector with a pair of ring connectors, an inline fuse on the positive (red) one. For our 3rd gen Prius, I connected the positive lead at the bolt that holds the main 12 volt (positive) cable at the under the hood fuse box. It's under this plastic cover:
    Getting that cover off is a bit of a puzzle: I believe @NutzAboutBolts has a video on it, pinned at top of 3rd gen maintenance sub-forum.
    Also, there's limitted room for a spade or ring connector; IIRC I had to trim off the insulation covering the connector's base, and bend it to a right angle.
    The negative lead I connected to an nearby bare hold-down bolt, I believe on the brake reservoir bracket?
    When done, I've got a capped connector, in the front right corner of engine bay. I do need to pop the hood to get to it, but I can hook up my charger, and lower the hood just to, not slammed shut. If you're parking outside and security is a concern, that may or may not work for you. The flipside: if your plug is accessible from the outside, someone could short it out?
    Raytheeagle likes this.
  2. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Ok...so we can do it both ways. Thx for the info!
    It just seems so much easier to hook up a quick connect to the battery itself though ( for me anyways )! (y)
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    @NutzAboutBolts did the video just for you;).
    Nice addition to the video collection (y).
    NutzAboutBolts likes this.
  4. Mendel Leisk
    42,373
    Yeah, if it's infrequent, alligator clips, either at the battery or the under-the-hood jump point, are the way to go. Ours tends to sit for days, frequently, so quick-connect was more secure/quick.
    farmecologist likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    There is NO "correct" method.
    Connecting it at any point which is "hot" all the time is fine.
    You do not need a permanent connection.
    Use the big clips at the "jump points" or at the battery itself if this is needed just occasionally.
    farmecologist and Mendel Leisk like this.
