Is the Prius too complicated?
Discussion in 'Gen 4 Prius Main Forum' started by Coast Cruiser, Oct 23, 2016.
  1. Al9
    Al9 New Member
    Chicago
    Just like anything there is a learning curve. Any new car has it's own new features.
    Coast Cruiser likes this.
  2. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I still think my Prius is the most complicated car I've ever owned. Techno-geeks, audio fanatics, and cell phone addicts will love it. But I like simplicity and ease of use.
    I am totally lost when it comes to all that Tech stuff. But I sure like getting 62 mpg! Reliability, low maintenance, and good gas mileage... that's all I wanted.
    I have 200 XM radio stations? I listen to 4.:ROFLMAO:
    I press the little button on the left side of the steering wheel... and that turns the "radio" on. Press it again, and it goes to AM, FM, XM. And the little arrow buttons change my stations... all four of them. I'm good! That's as "high-tech" as I'm going to get. Or want. :D
    RCO likes this.
  3. mikefocke
    4,080
    1,862
    Sanford, NC
    Complicated is setting the valve clearances with a feeler gauge, changing the points in the distributor, rotating the distributor till it sounds right (called setting the timing) , syncing the carburetors and torquing the head bolts and all of it about every 6 months. Oops, I forgot tightening the spokes, installing the inner tube, etc. Change the engine at least every 100k miles or maybe 30k if you are old enough to be driving a pre-war car.
    No seat belts, no airbags and no crash tests. And boy did those things crumble when hit.
    MichelleStone, RCO and Coast Cruiser like this.
  4. Coast Cruiser
    2,267
    2,571
    Yep, I remember doing the spark plugs with a feeler gauge, and installing new points and condenser, and trying to get the distributor right… (never did)... And watching my dad "boil the carburetor." I guess he was trying to clean it.
    So yes, the new engine technology is great. Fantastic! I don't miss those old days.
    RCO likes this.
  5. Mendel Leisk
    42,354
    I still do valve clearance adjustment on every Honda within reach. They have screw adjustment with lock nut, pretty straightforward. Well except for steeply raked windshield and tight quarters make it a bit of a pain on our (still in the family) Civic Hybrid.
    Coast Cruiser and RCO like this.
  6. bisco
    52,863
    i used to do valve adjustments weekly on my '72 fiat 123 sedan. maybe it was me.
    RCO likes this.
  7. Coast Cruiser
    2,267
    2,571
    Valve adjustments! Boy, that brings back memories. Tap-tap-tap-tap-tap-tap-tap-tap...
    I fondly recall the Honda service advisor, telling me that it's time for a "valve adjustment." My 1978 Honda Accord hatchback. A light blue beauty. One of the best cars I ever had.
    The other "best" car I owned, was my 1995 Toyota Camry. I still see a few on the road today. Simplicity at it's best. That 4-cylinder engine sounded like a sewing machine, but I never had one problem with that car in 11 years. Not even a little ding or scratch! (Unlike my new Prius, that already has 3 rock chips on the front.)
    bisco and RCO like this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I remember working on an old Ford Anglia (UK) 100E side valve engine. Alan can probably remember more details of that model than I can tho.
    Coast Cruiser and bisco like this.
  9. drajkuma
    drajkuma Need More Input
    Hatfield, PA
    Hey, I'm 49. But its good that you haven't seen me. I prefer to slink in the shadows and not be noticed at all.
    RCO, bisco and Coast Cruiser like this.
  10. Coast Cruiser
    2,267
    2,571
    "SEEN, but not heard." :) That's my motto with a white Prius. (For safety reasons.)
    Please everybody, turn your DRL's on when driving. Otherwise, an old dude like myself may just pull right out in front of you.
    RCO and MichelleStone like this.
  11. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The flying car?
    RCO and bisco like this.
  12. bisco
    52,863
    how'd it go then?:whistle:
  13. Mendel Leisk
    42,354
    Valve adjustments is how I always justified buying the Shop Manual for our slew of Hondas. Nice books, pretty well organized. More recently they are getting increasingly acronym ridden, to the point of complete unintelligibility, but hey. The section on valve adjustment was invaluable though: the sequence of rotating the engine, the cam shaft marks, intake and exhaust clearance specs, you needed it.
    Getting to the valves on older models was trivial: disconnect a hose or two, back out the valve cover bolts, you're there. The last time though, with a Civic Hybrid, comparable to (slightly easier tho) spark plug access on third gen Prius: you need to remove the bottom of windshield plastic and metal cowl. And there's a wiring harness running across top of valve cover, with no connectors. I got there but whew.
  14. bisco
    52,863
    you got that right. after a few times, i was able to adjust the valves on the fiat in about 20 minutes. there were a lot less of them too.
    #94 bisco, Oct 30, 2016
    Coast Cruiser, RCO and Mendel Leisk like this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Sort of. Same line but earlier generation, squared 3 box design. Harry Potter's model had a 105E engine and 4 gear transmission. The 100E drove the rear wheels through a 3 speed transmission. It also has those internal vacuum driven windscreen wipers that went flat out when coasting, but almost completely stopped when you put your foot down.
    Ah! Weren't those just the best times? :mad:
    Nice spot tho. Well done (y)
    bisco, Rebound and Coast Cruiser like this.
  16. Tideland Prius
    16,681
    And Autoblog just took a trip down memory lane.
    Junkyard Gem: 1981 Honda Accord LX Hatchback - Autoblog
  17. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I had a 1990 Ford Taurus Wagon a long long time ago. That car was a piece of crap! The car was only two years old and the ECU fried and melted. The transmission had to be rebuilt TWICE! The engine mounts were a constant problem. The alternator stopped powering the car and the column shifter always got stuck. The car would chug up the hill and sometimes died.
    I bring the car into the dealer too often and they decide NOT to honor the warranty (they probably thought I was trying to kill the car:p). This is why I'm against Ford and all other American automakers. They didn't stand behind their crappy cars. This was all in the first 3 years of owning the car!! I quickly sold it and got a 1994 Miata.
    I see what you mean by the Prius being too complicated, but I love the complexity and technology the Prius offers. For someone who has a long commute everyday, the Prius is filled with features to entertain. A whole decade will pass until someone becomes bored of using DRCC and wants something more advanced. I think the Prius appeals to a wide range of people. Old people love it because it's not too fast and it's easy to live with. I'm not a DIY guy who tries to fix everything himself on his Prius. That's when I get confused. The nice thing is that the Prius can be driven without attention needed to all the gauges and lights. I just prefer to drive a car with that stuff on because I'm a "techie". The only gauge I look at is the HUD. And to be honest, if you take out the MPG gauges, the Prius pretty much has the same complexity of every other car on the market.
    So why did you sell it? Low MPG?
    That was the big thing when the gen 2 was new. Except people had never seen OR heard! :ROFLMAO::eek:At least now Prii are more common and they have the pedestrian alert noise.
    #97 'LectroFuel, Nov 2, 2016
  18. Coast Cruiser
    2,267
    2,571
    I was stupid. Never had a problem with that '95 Camry. It was good, basic, simple transportation. It would've gone another 10 years.
    I just "thought" I needed a newer car... but now that I've "matured" :LOL: all I really need is just something simple to get me from A to B.
    With the Prius, it's the weird, unexplained, odd things that occur that makes me feel the car is too complicated. But I guess that complication comes with the "technology."
    'LectroFuel and RCO like this.
  19. keymusic
    keymusic Active Member
    211
    113
    Southern California
    I just turn on radar cruise control and lane departure steering assist and basically let it drive itself. That keeps things simple.
  20. Rebound
    3,996
    2,645
    Portland, OR
    If you read PriusChat, everything in Prius seems super-complicated because this board is full of techies who obsess over every detail.
    But as far as just driving the car.... every car in 2016 has features like Bluetooth and stuff. I think once you just drive a Prius, you get used to it and it's complicated; I find it very comfortable and easy to drive.
    Coast Cruiser, RCO and Tideland Prius like this.
