Is there a consensus on which phone mount is the best with this model?
Discussion in 'Gen 3 Prius Main Forum' started by misterrunon, Feb 4, 2017.
  1. misterrunon
    misterrunon New Member
    california
    I bought the wizgear magnetic vent mount, and the fit is not the best since the vent is vertical. I was wondering which ones you guys have found to be the best mount?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I use a nimbus mount in place of the stock shifter:
    With the new texting laws in CA, this is a good option. There is a magnet in the mount, and a corresponding magnet for placement in your phone.
    $20 on Amazon(y).
    bisco and Dreamerzcc like this.
  3. misterrunon
    california
    If your phone is mounted to the shifter, isn't it kind of a hassle shifting? Especially if you have a bigger phone, like the Galaxy Note.
    seeh2o likes this.
  4. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    I only shift twice(reverse to get out of a spot, then drive), and not while driving;).
  5. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I use Pro Clip in my Prius. I like it a lot. Lots of mounting options and you can get a different device holder if you change phones.
    taxicraig likes this.
  6. saltdiscus
    saltdiscus Member
    198
    89
    US
    After going with so many bad apples i found this to be the best in function and quality.
    iOttie Easy One Touch 3 (V2.0) Car Mount Universal Phone Holder
  7. FinToy
    FinToy Active Member
    145
    141
    Finland
    Where do you guys hang your phone? I have tried several different holders but still haven't found the proper one. Price also matters since I need to buy the same for 3 cars...
    Anyway, what interests me the most is the location. I tried Proclip holder in here. The problem is that my OnePlus 3 is so big I cannot see the displays properly. Also the charge cables are a mess in here.
    Then I tried the next option:
    It's so low I cannot see the phone navigator warnings. However, the location is good for the charge cables.
    There's also a window mount but pulling a "normal" charge cable there is a problem.
    Any ideas?
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    See post #2 above for the Nimbus mount. It replaces the shift knob and does not block the view of the HSI screen. It securely holds my iPhone and allows for charging while mounted and the cable is not all over the place.
    Based on your location criteria listed, the Nimbus might be a good option(y).
  9. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    I've got this one from Panavise. The photo is not my installation, my actual phone holder is a little smaller.
    Lightning Racer likes this.
  10. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    I work in an area of San Francisco, near Bonhams Auction House, that has many car break-ins and needed a mount which would go unnoticed. I saw the ironically named Steelie at a neighborhood Orchard Supply and it has been excellent.
    It's mounted just to the left of the center vent. The chrome ball has been brushed to lower the reflectivity.
    The only issue you need to accept is the small magnetic bump on the back of the phone. (see last image)
    seeh2o likes this.
  11. FinToy
    145
    141
    Finland
    Thanks guys! Need to investigate which would be the best option to buy from here.
  12. Markdizle
    Markdizle Member
    110
    76
    Huntington Beach
    Nimbus from amazon, $20! Doesn't get in the way or look hidious like some other mounts. Seamless integration
    Raytheeagle likes this.
  13. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Welcome to the Nimbus club (y).
    Markdizle likes this.
  14. Dreamerzcc
    Dreamerzcc Member
    67
    82
    Hoover
    This is what I use for my iPhone 6S Plus
  15. FinToy
    145
    141
    Finland
    Just browsing our local store yesterday, found this. Fits cup holder, might even work. But that price... :(
  16. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    I use the side window pro clip one. It is perfect in terms of functionality. Was high priced but worth it to end the discusssion for good. I use a 6 ft (2m?) cable to reach it for charging that has to be draped over the steering wheel if I am using it. Hasn't been an issue so far.
  17. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I have one similar to this, and just like the picture, the phone flops around.
    Someone on this site posted that they use this one so I ordered and really like it, holds the phone where I put it and magnet is plenty strong.
  18. jm64
    jm64 Junior Member
    25
    24
    Bay Area, CA
    2014 Prius Plug-in
    After reading this thread, I got the Nimbus mentioned earlier and have been happy with it for the last month.
  19. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Another Nimbus club member (y)!
  20. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Here's my setup, iOttie magnetic air vent mount.
