Is there a fix for the LED headlight" chi headlight system" error????
Discussion in 'Gen 3 Prius Technical Discussion' started by sfv41901, Feb 3, 2014.
  1. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Just from the little green relay as I understood...
    SCH-R530M ?
  2. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Sorry for the blunt response earlier. I was sitting in Church with my Son and 11:00 Mass was about to start!
    Experience is probably just as important as school knowledge, or at least my home wiring issue was solved by a professional electrician where I was convinced I needed to go into the attic.
    I found, miraculously as I am disorganized, the wiring diagram to the headlight to the '12 Prius v. I am currently trying to count the number of wires into the headlight assembly...
  3. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Five wires as far as I can see. There is a node to ground from the headlight assembly and is also connected to what looks like pin #3 of the DRL Module (aka Relay) that may look like a 6th wire, again, that is if the car has DRLs.
  4. defrankond
    defrankond Member
    217
    23
    North Dakota
    Idk. I think the led are plenty bright. I do not have any issues seeing with them. My worry is cost if they fail. Hid are expensive so I can only imagine
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Don't worry too much. Go to a local Lowes and check out the bulb section. If you look carefully at the LED replacement bulbs they have a lifespan of over 20 yrs at 3 hrs of use a day, or something super like that....
    iPad ?
  6. Pejman
    Pejman New Member
    Georgia
    2016 Prius c
    can you tell me if you solved the problem, i have similar issue on Prius C
