Is there a forumla to know the cost for each Empty-Full EV charge?
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Apr 25, 2017.
  1. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I don't do the timed charge, I use the charge as soon as you plug in. So, it's usually plugged in all night.
    So maybe it does heating ? But doesn't the real heat come from charging.
    I guess I'll learn more in the summer.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    It's because your efficiency is so low (2.5 miles per kWh). Mine is 4.9. You must be driving either very harshly or at very high speeds to have an efficiency that low.
  3. PDXMTB
    PDXMTB New Member
    Portland Oregon
    What does that have to do with the charging rate overnight to a full charge question I was asking?
  4. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    Nothing to do with charge rate over night. Any EV, including Prime, estimates EV miles based on one's previous driving. Mine is about 5.1miles/kWh and getting 35~37 miles displayed at full charge.
    #64 heiwa, Apr 27, 2017
  5. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    My 2017 Prius Plugin has a battery heater. It is not for charging AFAIK. It is to enable the battery to work more efficiently or effectively when driving in cold weather.
  6. bisco
    52,862
    yes, i'm not sure this 'battery pre heater conditioner' has been properly defined yet.
