is there a gen3 engine replacement DIY?
Discussion in 'Gen 3 Prius Technical Discussion' started by faciest, Aug 26, 2017.
  1. faciest
    faciest New Member
    22
    22
    longview tx
    Sorry i tried to search but can't find anything about this. Is there a DIY for engine replacement for a gen3 (2010-2015) Prius out there? I bought a 2010 prius with bad motor and im doing the engine replacement right now. It would be nice if we have a DIY so it would make my job a lot faster. Btw this is a 2010 Prius, the engine has a hole in it. Not sure why?
    PriusMechanic and m.wynn like this.
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    You might find this thread of interest: Blown Head gasket rebuild....@297k | PriusChat
    If you’re not using it already, I’d recommend Toyota’s Repair Manual for the 2010 Prius (RM1290U or RM1291U), available by subscription to techinfo.toyota.com, and perhaps also via your local public library, if they sponsor access to the ChiltonLibrary service for their patrons. The Repair Manual includes illustrated, step-by-step instructions for removing and installing the engine assembly and the other parts involved. It also gives fastener torque specifications and identifies required equipment and special service tools.
  3. faciest
    faciest New Member
    22
    22
    longview tx
    Thanks! that thread will help me quite a bit. Now I know i have to pull the engine from the top!
  4. JC91006
    16,936
    8,647
    How much did the car cost you?
  5. faciest
    faciest New Member
    22
    22
    longview tx
    it was $1100 + 820 for a used engine.
  6. JC91006
    16,936
    8,647
    Wow a bargain, for both.
  7. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Take plenty of pictures! (y)
    Aaron Vitolins, Grit and Raytheeagle like this.
  8. faciest
    faciest New Member
    22
    22
    longview tx
    Sorry i didnt read your post. Here are some pictures of the recent engine replacement. So we decided to go with the hard way which it dropped the engine and transmission from the bottom of the car instead the top. The used engine we purchased off a crashed vehicle with broken intake manifold. The plastic pieces from the intake manifold got into the valve and i couldn't turn the engine manually. I had to spray some brake cleaner and burn it for the plastic pieces to melted out so i can turn the engine freely. After that everything went smoothly except for the P-lock cable didnt get plugged in all the way and I can't start the car cause it wasnt in park. After plugged it in all the way the car start and run like a champ.
  9. MacMarty15221
    MacMarty15221 New Member
    Pittsburgh, PA
    A little late for OP's purposes, but here is a video.
    VEZzie likes this.
  10. PatrickBrian
    PatrickBrian Member
    64
    Pittsburgh
    2014 Prius v wagon
    It comes with the kit :LOL::LOL::LOL:
  11. bisco
    52,863
    cool video!
    i could probably get it apart, but it would never go back together, and there'd be a whole lot of leftover parts :ROFLMAO:
  12. PatrickBrian
    PatrickBrian Member
    64
    Pittsburgh
    2014 Prius v wagon
    That's what I thought only 2 weeks ago, yet here I go. Just backed it into the boathouse (20x13 enclosed carport), and I'm going to have a bite to eat before I start. Kinda like a "last meal"
  13. PatrickBrian
    PatrickBrian Member
    64
    Pittsburgh
    2014 Prius v wagon
    This was completely cleaned out two weeks ago, including the EGR circuit and replaced the PCV. PXL_20221031_215157656.jpg
  14. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Good luck. Your engine had a hole in it because it likely threw a rod after running without oil, or some other catastrophic event.
    Before you put the used engine in the car, you might want to read about the problem with the 2010 to 2014 ish Prius engines with seized oil control rings and head gasket failures.
    How many miles are on the used engine? What year is it from?
