Is there a paint code for the AC vents?
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, May 10, 2020.
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    So the final things I need to do to make my Prius perfect are fix gouges and scratches on the interior
    The main being the plastic metallic colored AC vents and on parts of the center console and door arm rests
    I've tried about three different colors to match the AC vents and can't find an exact one
    I REALLY don't want take these off to paint or replace them if I don't have to.
    Also I really would like to know if there is a paint code or color that will look nearly identical to the gray plastic on the doors/ sides of the center console.
    There are gouges from where it looks like either a ladder or something scraped them in the 250k course of life this car has had.
    Any ideas?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    It's the metallic element that makes that hard to match.
    I'm not the authority on it, but as far as I know there is no paint code for an exact match.
  3. Mendel Leisk
    42,259
    @Elektroingenieur might know.
    A body shop could match it, but that more'n likely exceed the cost of just replacing the parts. Which is another option to consider.
    Maybe try disassembling it too: if you can manage it all the options become easier I think.
    If keeping it "stock" is not paramount, consider something like satin-black Plasti-Dip? it's available in cans (for dipping), or a spray can. Mask-off carefully and spray with the latter?
    Is this @3prongpaul's video? I might show the vent removal, I forget:
    #3 Mendel Leisk, May 11, 2020
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Compared to many other cars, they are fairly easy to remove (search radio removal/installation videos). With a screwdriver and plastic trim removal tool, I would remove all, disassemble and paint/clearcoat.
    GOOD LUCK!
  5. fotomoto
    5,639
    3,815
    So. Texas
    I wouldn't recommend plasti-dip for items that are operated/touched or are regularly cleaned or protected with chemicals. Plasti-dip is great to test out color choice or design ideas.
    #5 fotomoto, May 11, 2020
  6. Leadfoot J. McCoalroller
    8,269
    7,774
    Pennsylvania
    2018 Prius c
    I've been down this road in other cars. Usually the best way is to find a color you like and then paint all the interior trimbits you care about so that they match each other. That's a much easier task than trying to match the factory finish.
    Hobby shops have paints with metallic finishes that adhere well to these plastics, though hobby finishes often aren't very durable. You'll probably need to add a clear coat with something else to add scratch resistance.
  7. Mendel Leisk
    42,259
    Yeah, even if you match existing paint, a newly painted single panel will stand-out. Good idea.
  8. Elektroingenieur
    2,515
    3,288
    Three Touring
    @The Electric Me is correct. There are codes for the interior trim colors, but as far as I know, the specifications for the colors and finishes are proprietary to Toyota. It’s not like the situation with exterior colors, for which Toyota and others sell touch-up paint and paint systems to match.
    On the U.S. version of the certification label, inside the left front door, the four-character interior trim code appears next to C/TR, after the slash, but I think it’s meant only to help find the right replacement parts in the catalog. Typically, the first two characters identify the type of fabric or leather, and the second two characters identify the trim color. (The three-character code before the slash is for the exterior color.)
    Toyota part numbers can have color codes, too, usually in the eleventh and twelfth characters. For example, some of the interior trim pieces used on 2008 Prius cars have part numbers ending in “-A1,” ”-B1,” or “-E0,” for ivory, gray, or grege, used on cars with trim codes __0_, __1_, and __4_, respectively; a “-C0” suffix often indicates a part that is black or nearly so. The color names in the parts catalog aren’t necessarily the same as those in sales brochures, by the way.
    The Electric Me and Mendel Leisk like this.
  9. whitmanrf
    whitmanrf Junior Member
    28
    Miami
    There is a Rustoleum spray paint "Hammer finish gray" which is a very close match, in a shade of metallic gray, to the existing finish. If you overapply it, the hammered texture will become apparent. Start with a clean and lightly sanded surface... go easy with the spray; when dry, buff it with fine emery cloth, and clear coat it, and it may turn out close enough.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    For $35 you can get a new set of 4 from aliexpress.....heck, a rattle can cost $10 and the vents self destruct as soon as you touch them anyway.
    MAX2 likes this.
