Is there a way to check the effectiveness of battery?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sanjath, Jan 6, 2016.
  1. bisco
    51,900
    awful lot of negative assumptions being made in this thread. why?
  2. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Here's Page 7 for your convenience. It looks like my about 10% loss over 3 years fits the curve.
  3. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    Thanks for all the suggestions, I found that the easiest for me was to look at the Chargepoint logs/stats, since I have it only since Mar 2015, it did show some interesting things, on the overall graph it does look pretty flat. In the details, it looks like I started at 2.8 in Mar2015 and now in Jan 2016 it is 2.6, so that is 0.2 loss over the year. i.e: 0.2/2.8=~7% down.
  4. Mendel Leisk
    41,415
    How many miles on the odo now?
  5. bisco
    51,900
  6. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    This is not a completely fair comparison, as the times of the year are different. You can better check it again when you can compare the numbers for the same month. I will not be surprised if you get a much lower % then. Many others get percentages between 2% and 4% per year.
