Is there a way to drain the coolant from just the radiator,and not need bleed the cooling system
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Apr 26, 2018.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    A bit slow but, nice of the guy to do it.
  2. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Are you really recommending this as a legitimate way to dispose of used coolant? I recognize engine coolant (and especially the pink stuff) is different from used oil, but come'on.....there are better ways. We should all be a bit more responsible than that.
    How do I dispose of antifreeze?
    Make sure the antifreeze is in a safe, closable container to prevent spills. Contact local recycling centers and service stations for more information on local disposal. Do NOT pour antifreeze down the drain. Do NOT pour antifreeze outside. The content of your antifreeze, whether it is new or used or mixed with another fluid, is important. Take note of the makeup of your antifreeze when inquiring about local disposal methods.
  4. Mendel Leisk
    41,464
    Yup, up here Mr. Lube takes engine oil, brake fluid, coolant, you name it. (y)
    Sadly, the area around their waste oil tank is an oily mess, and I've seen them pressure wash the area with detergent, and it all washes into a nearby stream. :mad:
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Nope. The black plastic cover bottom ends right under the rad. But don’t be surprised if that bottom cover is all tore up and ready to fall off. The front end of our car is very very low and will catch every curb so it takes a
    Beating.
  6. ski.dive
    964
    244
    edthefox5
    Followed your instruction and ''ONLY'' FLUSHED THE RADIATOR
    =NO BLEEDING NEEDED
    Thank You for the TIP!!!
    edthefox5 likes this.
  7. Prius717
    Prius717 Junior Member
    51
    Lancaster County PA
    Is this still a good way to drain/fill the coolant/ I need to get mine changed on my 08.
  8. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Best way is just open the radiator drain petcock and dump the rad. Its a white plastic plug on the drivers side on the bottom of the rad. Its rather hard to see have to fight your way thru the hoses there. Sorry cannot remember the socket size.
    Open the top rad cap get a big container under the rad and then open the white plastic drain plug. When it stops dripping Close the drain plug and fill it back up with Toyota LLC.
    Your done!
    next day after driving it let it cool down and open the rad cap up and see if it needs a little more coolant. I have left the top plastic cover screws off so I can readily check the rad level. The cover is not going anywhere the hood when closed clamps it shut.
    Do that drain again in a few months. That will really really help. The alternative is a full engine/chrs drain and that's a real hassle to get all the air out.
    Also I would change the water pump belt. If its older than 75,000 miles it should be changed.
    mr_guy_mann and Prius717 like this.
  9. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
    From the service manual 2008 coolant radiator drain and fill.
  10. alftoy
    1,132
    517
    Inverter coolant drain and fill looks to be a separate procedure.
  11. edthefox5
    10,096
    4,833
    Clearwater, Florida
    yes there completely separate loops.
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
    The method is known as fractioning. You change part of the coolant with new, let it mix, then do it a couple times more. You don't get all of the old stuff out, but eventually you get a "high" percent.
    I would do it maybe three times total over a few weeks then not worry about it for 5 years.
    While not as complete as totally draining the system or using equipment to flush it all, fractioning is a reasonable means of exchanging coolant while minimizing problems.
    The process is similar to what you do on many automatic transmissions. Drain the fluid in the pan. Fill with fresh. Run it a while. Repeat several times.
  13. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    Reviving an old thread I know, but I wanted to say thanks to @edthefox5 for posting this. I’ve dreaded the idea of bleeding the ICE coolant system using the long and drawn out methods seen on YouTube. The ‘fractioning’ method is a breeze! So far I’ve only done it once, will do this again in 2 days to get more of the old out.
